Your favorite way to get cranked Marshall tones at bedroom levels?
Discussion in 'Marshall Amps' started by jchrisf, Jul 2, 2020.
  1. jchrisf
    jchrisf Well-Known Member
    Feb 27, 2016
    694
    671
    Do you use a modeler? A pedal? A PPIMV or Master Volume amp? Attenuation? Reactive Load? Cab face down on floor, etc.? What is your favorite method?
    Pillingerap, bluesguy62 and wntbtw like this.
  2. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    897
    1,343
    Put all the knobs on 10. Uck the neighbours - what did they ever do for me?
    Lodybo, JAC, Rick in HB and 12 others like this.
  3. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,040
    1,973
    Wilton NSW
    Crank the Marshall's in the bedroom. (using an attenuator)
  4. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,340
    1,076
    MV. Jcm800’s just above tv volume.
    Rusty Strings, FogDweller and wntbtw like this.
  5. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,201
    1,126
    house arrest
    All work well for bedroom playing. Reording levels would be slightly different.
  6. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,067
    1,027
    Never had any problem, all my amps work. In fact, I can go low enough to hear the strings on the guitar over the amp.
  7. Big Mike
    Big Mike Active Member
    Nov 15, 2007
    106
    46
    Raider Nation - SFO Bay Area
    PPIMV Is decent enough. I prefer reamping with a dummy load
  8. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    634
    645
    Iowa
    PPIMV on my JTM 45 for bedroom playing. Sounds great, and when I record I just turn it up a little louder but not too much. I get nice cranked amp tones out of it at reasonable volumes.
    Crikey and Gblev like this.
  9. tce63
    Aug 6, 2018
    1,656
    4,356
    Sweden
    As @JohnH says !
    "Crank the Marshall's in the bedroom. (using an attenuator)"
  10. JacksonCharvelAddict
    Mar 4, 2016
    1,788
    1,844
    I run my Jubilee 100w at 6 on the master and it is low enough that I don't think the neighbors can hear it. I play in the basement so that helps alot for the noise. The wife complains if I get it any higher than that. If I need it to be quieter i will run my Kemper in the FX return and load my profile of the Jubilee and I can get that cranked tone at much lower volumes.
  11. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    361
    353
    Ohio
    JCM602 + JCMC212
    Clean Volume 1/10
    Overdrive Gain 0.5/20
    Overdrive Volume 0.5/10
    Master Volume 7.5 to 8/10
    No distortion, overdrive, fuzz, or boost pedals.
  12. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    2,122
    3,920
    Texas
    Easy....1987X with Pandora mod, set at conversation level = really good
    Set at 2 or above = great
    Set at 5 or above = :drool:
  13. marshallmellowed
    Jun 26, 2009
    3,834
    4,763
    Aside from cranking a Marshall in a bedroom, it can't be done, as the speaker(s) are barely working. The closest I've gotten at "bedroom levels", which is assumed to be very low levels, is using my Axe Fx. Using an actual amp, the obvious choices would be a load/re-amping device or reactive attenuator, but again, the speaker(s) are barely working.
  14. Seventh Son
    Seventh Son Well-Known Member
    Jul 24, 2014
    757
    837
    Naples, Florida
    Bass 5
    Middle 10
    Treble 2
    Presence 3
    Volume 1
    Gain low
    Tube Screamer in front as a clean boost
    This delivers some useable tones at low volumes.
    FogDweller, Trelwheen, wntbtw and 2 others like this.
  15. What?
    What? Well-Known Member
    May 17, 2018
    551
    474
    What's the Pandora mod?
    tce63 likes this.
  16. MarshallDog
    Nov 28, 2010
    14,213
    14,878
    Taintville
    Attenuators, London Power Scaling, Master Volume and pedals! All used in various ways and combinations!
  17. RCM 800
    RCM 800 Well-Known Member
    Dec 20, 2019
    368
    689
    I have big amps (50w and 100w) and small amps (10w, 15w and 20w). Mostly use the small ones lately even with my band. If I had to be bedroom quiet, like with other people sleeping in the house, I would use Bias amp on my computer and use headphones.
    wntbtw, Mitchell Pearrow and jchrisf like this.
  18. junk notes
    Dec 10, 2018
    1,201
    1,126
    house arrest
    Yes, reamp! a little more to chew. :)
    Yes, the MP has an decent PPIMV. Makes it great for recording.
  19. Trelwheen
    Nov 18, 2017
    2,122
    3,920
    Texas
    ibmorjamn likes this.
  20. What?
    May 17, 2018
    551
    474
