YJM100 Boost (calling on the techs, please)
Discussion in 'Marshall Amps' started by crossroadsnyc, Mar 7, 2021.
  1. crossroadsnyc
    Feb 5, 2009
    21,315
    20,695
    Here's my question:
    The YJM100 has a built in boost, can you tell me anything about the placement of the boost w/in the amp? I'm not a tech, so while I'd like to share a schematic, there are so many things that come up in a search, that I'm not sure what to share. I suppose I'm curious as to the placement of the boost w/in the amp in comparison to using an external boost. An external boost makes sense to me, but when it's inside the amp, I'm not sure exactly what's going on.
  2. ricksdisconnected
    Aug 11, 2019
    5,461
    8,336
    in for the education.
    crossroadsnyc likes this.
  3. Dogs of Doom
    23,606
    27,682
    I think it's 1st thing, but, I bet Santiago knows exactly what's up, w/o looking... @santiall
  4. santiall
    santiall Well-Known Member
    Aug 12, 2010
    359
    857
    20210307_232638.jpg There you go, straight from the handbook
  5. crossroadsnyc
    Feb 5, 2009
    21,315
    20,695
    Thanks (my manual is tucked away, and I didn't even think to dig it out). This might be a dumb question, but does having the boost built into the amp react any different than having it out in front on your pedalboard? For example, when in front of the amp, you might be going through several patch cables, several other pedals, and then of course the long lead taking you into the front of your amp/FX loop, whereas having it built into the amp, you eliminate all of that.
    The reason I ask is because I can't figure out whether it's the particular boost built in that I like so much, or whether there might be a technical explanation as to why it works so well. There's just a naturalness to the boost that feels so much a part of the amp, and I don't get that with any other boosts (not only w/this amp, but others through the years). It's more like a natural extension of the amp if that makes any sense.
    One final question ... there's a lot of speculation as to which boost the YJM boost was modeled after (I've read everything from the YJM308 to an old school grey box DOD250) ... are you at liberty to say one way or another? If it turns out that the placement of the boost is irrelevant, it'd be nice to find out which boost it's modeled after so as to maybe pick one up for other amps (I really like it).
    Thanks again!
    LPMarshall hack likes this.
  6. ufguy73
    ufguy73 Active Member
    Nov 27, 2009
    346
    106
    i don’t remember exactly (and it wasn’t even the YJM but another amp that had a particular style of boost built-in that sounded better than very similar boost out front) but i spoke to an amp builder once about this concept and I thought he was saying something about the boost circuit running at higher voltage when integrated into the amp or something...
    maybe something like that is in play for the YJM too?
    WellBurnTheSky and crossroadsnyc like this.
  7. marshallmellowed
    Jun 26, 2009
    4,394
    6,245
    All subjective, of course, but I never noticed anything special about the YJM boost. It was OK, but nothing I hadn't heard before. Clean design, as it was built-in, but a bit limiting, as you only had control of the "Drive" level.
  8. bigbadorange
    bigbadorange Well-Known Member
    Oct 23, 2013
    323
    452
    las vegas
    Just for the record Im with you on something going on. I rolled dozens of other overdrives, and happen to have several 4 holers. None sound as good as the YJM with its built in boost. And its interesting as without the built in boost, it DOES pretty much sound like any other four holer. There IS something more going on.
  9. santiall
    Aug 12, 2010
    359
    857
    it is YJM308 powered at 9V.
    If shouldn't make much difference having it inside or outside when engaged but when using an external pedal, if the effect is OFF, it'll depend a lot on your cables or whether you have anything buffering your guitar signal before the overdrive
  10. crossroadsnyc
    Feb 5, 2009
    21,315
    20,695
    Thanks, dude ... this has been on my mind for a while now, so it's nice to have a better understanding. It looks like I'm just a fan of the YJM308!
  11. crossroadsnyc
    Feb 5, 2009
    21,315
    20,695
    Yeah, a tone control would be nice, but manipulating the EQ works just great for me, so it's not a deal breaker by any stretch.
  12. crossroadsnyc
    Feb 5, 2009
    21,315
    20,695
    Sounds like the secret is the YJM308 :hmm:
    I'm totally going to have to get one now and do a comparison.
  13. santiall
    Aug 12, 2010
    359
    857
    have fun!
  14. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,556
    2,344
    Las Vegas, NV
    I'm gonna make a guess here and bet that the "on board" boost has had the impedance and levels more closely matched to the circuitry of the amp, as opposed to having it be a "one size fits all" approach to operate in front of any amp!
    Again, Just A Guess?
    Gene
