Why Won't My Lawnmower Start?
Discussion in 'The Backstage' started by Vinsanitizer, May 11, 2017.
  1. Lo-Tek
    Lo-Tek Well-Known Member
    Aug 25, 2013
    4,574
    3,586
    Traverse City, Mi.
  2. chiliphil1
    chiliphil1 Well-Known Member
    Nov 6, 2014
    4,846
    2,963
    Welcome to the world of ethanol fuel. As a motorcycle tech our business has become 80% cleaning carburators that have just come out of winter storage.
  3. Gunner64
    Gunner64 Well-Known Member Gold Supporting Member
    Nov 16, 2013
    6,429
    8,457
    Midwest, USA
    Yea if I forget to run the fuel out of my snowblower at the end of winter I' ll spend an hour freezing my ass off trying to start it the first time I try to use it the following winter, and thats regular gas.
  4. Gianni
    Gianni Well-Known Member
    Sep 13, 2014
    2,647
    3,676
    Greece
  5. Derek S
    Derek S Well-Known Member
    Nov 24, 2010
    2,104
    3,269
    Rock Ridge
    I had this same issue last year with my fairly new mower, seems I also left a good bit of gas in the tank over the winter, so come the spring it refused to start. I brought it into work and a co-worker educated me on this whole "winter storage" thing. He proceeded to remove a few things so he could reach the carburator but all he did was tap on it a few times with a hammer lol - put everything back in place and voila, fired right up. Lesson learned, either run it dry at the end of the summer or crank it up several times throughout the winter months (I did that this year and of course it's starting like a champ now that I run it weekly).
  6. Bear R.
    Bear R. Well-Known Member
    May 23, 2008
    2,261
    1,707
    N.E. Arizona
    There should be at least a primer on it so you can prime the carb...
  7. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    2,624
    3,907
    At Home
    I add a little Sta-Bil to 4 and 2 stroke mixes. Run the gas out at end of season. I use premium gas for the 2 stroke tools and dump what's left of a 3 month run and mix again. No problems here, old push mower started on first pull this spring.
    Biddlin likes this.
  8. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    985
    890
    Brit in California
    The push reel mowers can be great IF you don't let the grass grow too long in between. I have a fiskars which improves efficiency by 30% (they have better ones) and it's easier than the petrol push mower so long as the grass is less than 4". So right now I have to do it every week, in the summer every fortnight.
    It's incredibly sharp and spreads the clippings evenly so you don't need a collector bag. It weighs less than the powered one making it easy to push.
    The cheap reel mowers are a joke though. I tried one when I had a rental and it was a LOT of work. 3" grass was like trying to pull off while driving with the handbrake on.
  9. Biddlin
    Biddlin Well-Known Member
    Aug 21, 2013
    4,068
    4,663
    Old Foothill Farms, Califusa
    I went to an electric mulching mower about 10 years ago and have never looked back. I hated storing gasoline, the first start of the spring and all the other hassles of a gas mower.
  10. tone seaker
    tone seaker Well-Known Member
    Jan 20, 2011
    3,092
    3,444
    Where the Rock Rolls Hard and the Blues Rains Down
    I use to be a mower mechanic and its deffently a fuel problem. They are simple if it sparks then its fuel. I leave mine for months with out starting and have no issues. Unleaded fuel is not like old leaded that varnishes. It takes years to varnish fuel now days but its a fuel issue for sure. :)
  11. pedecamp
    15,610
    13,435
    Spray some starter spray in the carb, it will start on the first pull.
    tone seaker likes this.
  12. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    2,137
    2,153
    The Institute for the Very, Very, Very Nervous
    Move south Vin, we now 12 months a year.
    Gianni likes this.
  13. Marshall Stack
    Marshall Stack Well-Known Member
    Apr 15, 2011
    2,462
    3,255
    St. Louis, Mo.
    That has worked for me before when I couldn't start the engine.
    pedecamp likes this.
  14. Marshall Stack
    Apr 15, 2011
    2,462
    3,255
    St. Louis, Mo.
    Interesting...
  15. Antmax
    Aug 7, 2015
    985
    890
    Brit in California
    Here's a video of someone using my reel mower. One handed with a gopro on a broom handle as a selfie stick.
  16. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    997
    1,569
    Canada
    Is your engine two stroke or four stroke?
  17. Vinsanitizer
    Vinsanitizer Forum Support Spec. Double Platinum Supporting Member VIP Member
    Oct 19, 2012
    27,976
    22,267
    Regular gas, no mix. I got it running. I poured gas into the spark plug hole a few times hoping to prime it. A bunch of black stuff came out of the muffler and then it started to run on its own, the frigging thing. Some of you's guys crack me up. :D
    mirrorman and mcblink like this.
  18. pedecamp
    15,610
    13,435
    Once you get it started it will burn off whatever is fouling the motor.
  19. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    4,105
    3,562
    Dallas
    Have you tried cussing and swearing at it? That's my go-to! :realmad:
  20. Marshall Stack
    Apr 15, 2011
    2,462
    3,255
    St. Louis, Mo.
    Followed by pleading and begging...
    Vinsanitizer and jmp45 like this.
