What's your relationship like with your Gibson LP
Discussion in 'Guitars' started by Gaz Baker, Apr 14, 2021.
  1. Dean Swindell
    Dean Swindell Well-Known Member
    Mar 12, 2017
    424
    415
  2. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    10,363
    11,884
    Choose:
    obx351, Old Punker and Gaz Baker like this.
  3. Dean Swindell
    Mar 12, 2017
    424
    415
    I don't think weight has anything to do with it. My SG Junior sounds incredible - and it practically floats at 5ish pounds, whereas my Standard is unusually heavy and sounds great too, just different. And one of my two teles is quite light and is a monster. I spent the late 70' and all of the 80's thinking heavier guitars sounded better but it just isn't the case. There's no key formula between weight and tone. My '71 LP Deluxe sounds great but not really better than the others, and I'm betting, once I weigh it, it'll clock in about 12 to 13 pounds.
  4. axe4me
    Feb 28, 2013
    10,363
    11,884
    This is a feather................
    obx351, Deftone, Gaz Baker and 2 others like this.
  5. pittbull
    pittbull Well-Known Member
    Oct 8, 2009
    1,311
    353
    2014 Gibson Les Paul Traditional Floyd Rose 50s wiring Kolev hand wound pickups that sound beyond amazing sustain for days.
  6. Sapient
    Sapient   Silver Supporting Member Gold Supporting Member
    Mar 14, 2020
    5,314
    10,172
    Yes
    Those are some pretty chunky fillets. I'm suspecting some rather substantial areolas.
    Mitchell Pearrow and Gaz Baker like this.
  7. Gaz Baker
    Gaz Baker Well-Known Member
    Feb 15, 2017
    580
    1,953
    I think I'll go a set of mules in my LP.
    Not metal oriented, but will cover a lot of ground.
    It's my Ibanez RG I'll kit out for metal, but I'm not sure of which set. The Aftermath set are harshly trebley.
    And I'm not interested in a metal specific set.
    So at the moment I'm looking at Juggernaut's, Silo's, or Holy diver's.
    I play from clean to modern metal, but mainly hard rock, punk and 80s metal styles
    John BNY likes this.
  8. Scumback Speakers
    Sep 16, 2016
    1,166
    1,870
    Los Angeles, Ca
    I have ten Les Pauls in the closet, the harem is jealous of each other, but they love me individually. LOL
  9. giblesp
    giblesp Well-Known Member
    May 3, 2015
    492
    555
    MY LP Studio is one of the best LP's I've played. I went into a shop with a Traditional in mind, but decided on the Studio. Just played better for me.
    The issue I have is with the nitro finish; though yellowing was to be expected I literally have a dark stain where my arm rests. Pretty sure the older, vintage nitro Gibsons weren't as fragile. That could be due to lower VOC's in the finish, or the thinner application of nitro.
    Other issues, one of the trapezoids has come loose after 4 years of home use. A common Gibson problem.
    If I had the choice, I'd have chosen the 'Swiss Cheese,' weight relief. I can appreciate the resonance of the modern weight relief, but the treble position does get a little thin compared to LP's with less weight relief. Not a deal breaker though, and though its a little weird to have an LP lighter than my strats its become part of the individual character of the guitar, which I wouldn't change.
  10. Sapient
    Mar 14, 2020
    5,314
    10,172
    Yes
    Done:
    That was fun.
  11. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    1,530
    4,292
    Ontario, Canada
    Yeah my SG is only 6.5 lbs. but can rip my head off through any decent amp!
  12. Old Punker
    Jun 17, 2020
    1,530
    4,292
    Ontario, Canada
    @giblesp - I sometimes get cloudy areas on my LP Studio too, both where my arm sits and around the volume/tone knobs. IME the best way to keep this from getting out of hand is to use a good polish like Gibson pump polish and wipe down your guitar after every use. If you already have a discoloration then you may need another product to help reduce/eliminate it. Years ago a guitar tech sold me some GHS Guitar Gloss and told me to use it only on the afflicted areas and it did a great job on my Studio. I had to apply several light coats, let them dry, and buff them off. After a while I could really see the improvement. Now I only need to use it occasionally. I've also heard that another product called Virtuoso Polish/Cleaner works very well too. Your degree of success may depend on how bad it is?
    Which bridge pickup do you have in your Studio? I've got the 498T in mine, which is also weight relieved, and I haven't really noticed any problem with 'thinness'.
    Do you know how much yours weighs? My Studio tips the scale at 8.2 lbs.
    :cheers:
  13. obx351
    obx351 Active Member
    Oct 12, 2012
    135
    192
    WAIT, there's a guitar in this pic??
  14. Thevenin
    Thevenin Well-Known Member
    Jan 19, 2019
    282
    565
    Austin, Tejas
    After 50 years on this earth, I have yet to play a LP. I own 3 SGs and a Firebird so I imagine a LP is somewhere in that mix. Cancelled my Epi 1959 order and still looking around on CL for a Gibson that is priced right. Kind of tough right now.
  15. axe4me
    Feb 28, 2013
    10,363
    11,884
    I think Gibson's Les Paul, along with a Strat, is my most traded and sold guitar I've ever owned.
    It's not that I think a Les Paul is bad................it's just, IMO, one of the most coveted guitars I'll ever part with and my most, "I really want".
    I never part with a guitar if it's bad.................except my, long gone, Aria ZZ or early 60's Epiphone Coronet (they were god awful).
    Gaz Baker and Old Punker like this.
  16. Deftone
    Deftone Well-Known Member
    Feb 9, 2021
    621
    1,860
    Auburn, CA
    I used to think they were lame. I liked my Charvel, Jacksons etc.... Then I bought an Explorer and was pretty amazed by the tone. So my neighbor says: "If you like that, try my Les Paul." And he loaned me his '84 Standard with EMG's. Absolutely floored me. I gave him back his LP and I told him I had ordered one. A 2000 LP Standard Raw Power. Should have kept that one.
    IIRC there were four more since then: a Studio, Studio Lite w/floyd and two Custom Lites. I own three LP's now:
    1979 LP Custom
    1989 LP Custom Lite w/Floyd (Only '89 & I've seen less than 10 of these)
    2014 Standard Light Flame 120
    I became pretty obsessed with '87-'89 LP Custom Lites.
    LP's are #1 for me. Nothing sounds as good to my ears.
  17. RobV
    RobV Member
    Sep 13, 2008
    90
    75
    Digging the line up! What is the blue one?
    I love the feel of my new one, so much so that I let go of my SG for a Mesa.
  18. Old Punker
    Jun 17, 2020
    1,530
    4,292
    Ontario, Canada
    I see the Mesa Single Rec head in your sig, I recently picked one up too. Love the Vintage mode. Killer with a Les Paul and an OD808 boost.
    I kept my SG though.
    :cheers:
    Gaz Baker and RobV like this.
  19. RobV
    RobV Member
    Sep 13, 2008
    90
    75
    My plan is to get a P-90 SG next, both my other guitars a double HB's. I haven't really played my Mesa yet at home, tried it out at my instructors studio but have been sick as a dog since I got it, finally feeling better so hopefully I will be back to normal in a day or 2 :)
  20. Old Punker
    Jun 17, 2020
    1,530
    4,292
    Ontario, Canada
    Hope you feel better real soon. Maybe looking forward to playing the Recto will help you recover faster.
    Because of the extra volume control (Output) I find these are good for getting nice saturated tones at lower (home) volumes. I hooked up my P90 guitar (Mosrite copy) to it when I first brought it home and it sounded great. The Mesa made it sound 'bigger' than it does on my other amps. The only thing I'm not crazy about is the parallel FX loop, but I'm slowly learning how to deal with it.
    :cheers:
    RobV, Mitchell Pearrow and Gaz Baker like this.
