Whats your preference 50 Watt or 100 Watt?
Discussion in 'Marshall Amps' started by 1956tvmodel, Jan 23, 2021.
  1. Dan Sing
    Dan Sing Member
    Jun 12, 2020
    27
    34
    :bowdown:The killing floor... 15 years ago, i bridged three of them (with their double-cabs), a Hendrix-handwired 100Watter SLP 1959, then a 1976 SLP 1959 (100W) and then a new SLP 1959 (100W) from around 2000, all 4 holes without Mastervolume. Was fine, the best i ever had. The guitar was more rarely cranked, beautyful sounds at any position. Yes, at that loudness, pickups, tubes and speakers start an own conversation (replacing a lot of pedals). Only a Dunlop-wah was there and from time to time i switched on a Mrshll-jackhammer in overdrive, more fuzz-like.
    Still i play two of them, only the Hendrix handwired is out of reach actually. Yes, i have tinitus, and i do rarely play all flat out meanwhile because i live not more where i lived then (inbetween the hills, in the forest, 3km around not one human neighbour). And i own 4 pedals meanwhile plus a Helix, full of pedals. But it's not more the real thing
    Fletcher-Munson-effect, i tell you. The louder it is, the better we hear.
    ...too and specially the faults...
  2. Wooferhead1
    Wooferhead1 Well-Known Member
    Jan 19, 2019
    530
    934
    Ohio
    I never had the pleasure of cranking a 100 watt, would have love to when I was playing some outside venues. Did however crank my 50 watt 2266 and 2 - 425 cabs at a half dozen outdoor shows back in 2010, it had a killer sound clean or dirty with volume 7-8 on high gain, can't imagine a 100 watt. Used a standard strat and 81 Les Paul (pictured). Classic Rock - Love those cabinets.
    Mitchell Pearrow and Old Punker like this.
  3. Kidlargo
    Kidlargo Member
    Feb 8, 2017
    20
    53
  4. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    1,049
    2,405
    This was exactly my take and situation the first time i used my SV20H in a loud jam. Nothing was miked and only PA for vocals. Big difference in that versus a PA system where everybody is miked. In that situation i believe I'd been good.
    Look, I love my Studio Vintage but in that scenario i found myself wanting a 50 watt head.
    I had 50 and 100 watt heads before. I like 50 for the slightly extra gain.
  5. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    733
    1,759
    Ontario, Canada
    Yes! In all seriousness, if you are getting the tone you want, playing the type of music you want, in the room situation you are in...who cares what the wattage of your amp is? :2c:
  6. Matthews Guitars
    3,564
    5,248
    I've just ended up with all 100 watt Marshalls, except for the JTM45 reissue. I wasn't seeking out 100s specifically, but that's what deals have come along at the right time.
    A 100 watter is only 3 dB louder than a 50 watter. If a 100 is too loud for you, believe me, so is a 50 watter.
    If your cranked 100 watt full stack is measuring 125 dB on a sound pressure level meter at a specific location in front of the stack, and you replace the head with a 50 watter,
    you'll still get 122 dB.
    A 5 watt amp in the same speakers would make 112 dB.
    A Greenback has a sensitivity rating of 98 dB. So a one watt amp can drive it to 98 dB. At 25 watts, the max rating of a Greenback, the level is 112 dB.
    For true bedroom practice levels you don't want multiple speakers per cabinet (they do add up the volume level because there is more cone area radiating sound)
    and you don't want high sensitivity speakers, and you don't want to fall into the trap of believing that a 50 watt amp is much quieter than a 100 watt amp.
  7. Kossfinger
    Kossfinger New Member
    Sep 28, 2016
    4
    7
    100w amps are fantastic. Otherwise, Marshall would be known for ???
    Where do you use em?? Depends on your approach...
    I like amps turned up. That alone makes things difficult. I typically use 50w amps in clubs, with speaker count varying between 1x12,2x12,4x12... depending on volume sensitivity. I have used 100w 2203 in clubs with no issues. Typically I use 100w amps for outdoor gigs. They do sound/feel different than 50w amps. A good 100 will make your day. Trower was doing a gig in my town. He was using a 50?? I said something about it to him after the show, saying it sounded good. He didn’t respond. I would bet he didn’t like it as much. The 100w has more headroom, with a tighter bottom end.. as we should realize by now, Marshall’s aren’t bedroom amps. That’s not what they were designed for?? Of course I come from a time when 50 or 100 was all they made. Now you have plenty of power choices!
    Old Punker likes this.
  8. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    2,075
    2,131
    Calgary, Canada
    50 watts with quality transformers FTW
  9. Spooky88
    Spooky88 Member
    May 24, 2020
    27
    43
    There's not one indoor venue in Bend Oregon I'd use a 100 watt Marshall in. I'll be constructing my 36x36 x12 stick frame studio next year. I might get a full stack after I soundproof it. But it would just be for grins. I already know my JCM 900 4502 does everything I need.
  10. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    965
    1,494
    I only have one thing to say about that. lol!
    https://i.imgflip.com/3webdc.jpg
  11. trax1139
    trax1139 Well-Known Member
    Apr 1, 2011
    323
    809
    Right!
  12. Antti Heikkinen
    Antti Heikkinen Member
    Nov 22, 2020
    9
    35
    I play a 1959 Plexi into a 1936 2x12" and I've removed two power tubes to make it 50w.
    It's still far too loud. I've got a master volume at the back, and that's around halfway down, and it's still far too loud.
    What I do is I lower my in going signal a bit, which also makes it nicely noiseless and quiet even when I jump the channels and gains are past the noon mark...but it's rather clean when played gently. That's my sweet spot - sounds absolutely great.
    I find plexis need quite a bit of EQ as well, and I have two of them actually. Makes it really punchy spanky like a Plexi on ten but still clean - kinda like Chili Peppers under the bridge clean. Very 3D and crunches a bit when played hard.
    And then I add a little OD and that's it...my tone heaven. And it's almost but not too loud to play in a small room with the band.
    Old Punker, WellBurnTheSky and Crikey like this.
  13. JackTone
    JackTone New Member
    Dec 10, 2013
    15
    21
    Cotati, CA
    I've done the 100W bit, prefer 50W to lower wattage amps.
  14. nkd
    nkd Member
    Aug 30, 2017
    61
    69
    To be or not to be - 50 or 100 watts? A case for using a 100W amp.
    To put some statements into perspective - "100 watts are for stadiums or playing outdoors", they don't really hold water if we look at the following.
    Considering we don't all have FOH with dedicated sound people.
    To calculate the following SPL values a 4x12 with G12T-75 speakers, at a distance of 20 feet, is used.
    5W = 94dB
    10W = 97dB
    20W = 100dB
    50W = 104dB
    100W = 107dB
    Hard hitting drummer averages at 111dB, measured SPL.
    Since +10 dB is the level of twice the perceived volume, a 100W watt amp is perceived as twice as loud as a 10W amp.
    If the sweet spot for the desired tone is power tube distortion then the amp output is between 99 and 110% of amp capacity, and there will be no available headroom unless a 2 channel amp with master volume is used to create the tone in the preamp. Or two lower power amps are used to get the needed headroom for solos etc.
    my 2c :shrug:
    Crikey likes this.
  15. Chungaleta
    Chungaleta New Member
    Dec 22, 2008
    19
    5
    I love both, depending on the venue you can make them sound great. And I've never needed to kill the audience with 100 watters. You can get a sweet spot at around 6 if using a 2x12
  16. Crikey
    Feb 16, 2019
    965
    1,494
    Simple get attenuator and enjoy the amp or get mv marashall
  17. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    1,241
    1,109
    NJ
    I'll take a 100w for the same reason I'd want a muscle car with a V8 instead of a V6.
  18. Revv23
    Revv23 Member
    Nov 29, 2012
    19
    30
    I have 50W and 100W... The volume difference isn't really that noticeable. Mostly hear it in the "balls" of the amp so to speak. (100W is tighter... not too much difference in distortion. IMO) Anyone with an amp that lets you switch between power modes knows this to be true. Is it louder in total output? Probably with a DB meter.... Never been in a situation with either where I didn't have "enough" volume. You'll need ear plugs to dime either one and frankly the only impression you get is they are both FRIGGEN loud.
    Frankly my Germino 1986 (50W superbass) is the biggest ballbuster of them all because it distorts less than my 100w. Can absolutely rip heads off.
    In reality if you need more gain after you hit your desired volume you use pedals... or you have some sort of MV... or you have an attenuator...
    I also built an 18w clone around 15 years ago that rocks but with the speakers I have paired with it can get over run by a drummer. Small amps are for practice.
    Crikey likes this.
  19. NoelH
    NoelH Active Member
    Aug 31, 2012
    100
    103
    50 Watters. Every time. Why? You can turn them up and use more of the amp, if you will. Yeah, I know, the difference in dB isn't that much. But still, the 'sweet spot' for say a 2204 is more manageable than a 2203. And to me there always seems to be something sweeter in the top end. No this isn't a scientific analysis, it's just what I've observed of 4+ decades.
    The other thing I always consider, is that I'm ALWAYS mic'd. And I play with a keyboard player that goes direct, with a small monitor amp onstage. And, I really do not like my speaker cab(s) on-axis. I stay out of in front of my cab so I can interact with the band. I'm not hearing just me and the drummer. So for me a 50 watt half-stack is perfect.
    Old Punker and Mitchell Pearrow like this.
  20. Paulfmarshall
    Paulfmarshall New Member
    Apr 2, 2013
    6
    Calgary / Vancouver Canada
    I played professionally in the 80’s/90’s in Western Canada and we ran 16,000 watts in clubs for PA/Subs. The clubs in Calgary were huge with capacities over 1500 people. This was because of the liquor laws. Remember how decibels work. The difference between 50 and 100 watts is nowhere near double. Maybe 10% louder? On the other post about concert venues, a lot of bands have their cabs isolated below the stage. Some of the on stage cabs are empty fo looks.
