What Plexi pedal into a clean Marshall channel (like Origin)?
Discussion in 'The Tone Zone' started by BatmansMarshall, Jan 28, 2021.
  1. BatmansMarshall
    May 15, 2020
    292
    397
    Lives in the mid-range.
    I use a Friedman BE-OD pedal to make my Origin 50 sound like a JCM800/SC20H.
    What Plexi tone pedal do you use to make yours sound like a SV20/1959 SLP/Plexis family?
    70s hard rock basically. Origin friendly a plus.
  2. fitz288
    fitz288 Space-Time Curver Silver Supporting Member
    Apr 7, 2020
    1,505
    3,159
    Pittsburgh, PA
  3. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    1,247
    1,518
    Ohio
    Transistors are not able to deliver what you are seeking. Get an Electro-Harmonix English Muff'n.
    BatmansMarshall likes this.
  4. BatmansMarshall
    May 15, 2020
    292
    397
    Origin is a tube amp. Muff'n looks interesting but does it differ much from a Big muff pi?
    What settings?
  5. crossroadsnyc
    Feb 5, 2009
    21,358
    20,806
    I think I know what you're after. In my experience, Wampler does the best job.
    "JTM45/1959" - PlexiDrive
    Hot Rodded "1959" - Pinnacle
    MV "JCM800" - SuperPlex
  6. IOSEPHVS
    Feb 10, 2020
    1,247
    1,518
    Ohio
    The English Muff'n is based on the tone stack and gain stage of actual plexis, and uses two 12AY7 valves which can be swapped out for either 12AX7s or 12AU7s depending on the exact sound you're looking for. It's a plexi preamp in a box with no fizzy sounding transistors or diodes in the signal chain.
  7. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,839
    2,186
    Södertälje, Sweden
    Carl Martin plexitone really does a great plexi sound into a neutral clean sounding amp.
  8. Trelwheen
    Trelwheen Certified B.S. Launcher Double Platinum Supporting Member
    Nov 18, 2017
    2,735
    6,111
    Texas
    Radial's Plexitube is a brilliant example of a cranked Plexi-style pedal. One of the great things about it is it doesn't rob any low end while keeping the bottom tight and firm.
    I used one for years to throw a 2203 into meltdown mode.
  9. BatmansMarshall
    May 15, 2020
    292
    397
    These are all great suggestions. I am basically trying to emulate that 70s Deep Purple/Rainbow Richie Blackmore tone or that eras hard rock stuff.
    From what I can gather we are looking at a cranked Plexi family like a Marshall Super Lead 100/SV20/1959 with treble boosting like a Dallas Rangemaster Treble Booster and or tape delay pre-amp sort of stuff depending on how you want to set it up.
    So those pedals being talked about are exactly where I am aiming.
  10. IOSEPHVS
    Feb 10, 2020
    1,247
    1,518
    Ohio
    Blackmore was keen on the Marshall 1967 with KT88 valves, and the two inputs cascade creating a master volume.
  11. BatmansMarshall
    May 15, 2020
    292
    397
    I didn't know that but it makes sense he would want to be as loud as a Sunn :)) or a Diezel. I read somewhere he even had an additional power stage to cross the 100W threshold. Diezel Herbert is 180W with KT valves and looks like it opens up ripples in spacetime.
    This is one of my favorite improvisations from Blackmore.
  12. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,595
    4,019
    C-137
    Maybe this one?
  13. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,813
    4,750
    Been able to fine tune the Marshall's if needed pretty good with this. laGrange (3).jpg
  14. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    2,329
    2,950
    West Oz
    Dunno if Catalinbread had a RangemasterintoMajor pedal, but they did an RM/AC30 Galileo and an RM/Laney Sabbra Cadabra, be worth exploring.
  15. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,188
    2,203
    My MXR EVH 5150 od does a pretty good job , it does much more than just VH .
  16. BatmansMarshall
    May 15, 2020
    292
    397
    Yes, they do. It is called the NAGA VIPER.
    https://catalinbread.com/products/naga-viper
    I own Catalinbread stuff that sounds great
    However that Wampler Pinnacle that sounds like a Hot Rodded "1959" is really nice.
    jimmyjames likes this.
  17. jimmyjames
    Jun 15, 2014
    2,329
    2,950
    West Oz
    Yeah I have a Naga, using it atm :yesway: The other 2 I mentioned also combine a simulation of the particular amp. The Galileo is red hot compared with the Naga, 'cos it also simulates Top-Boost AC30, the Sabbra a cranked Laney.
  18. C-Grin
    C-Grin Well-Known Member
    Nov 8, 2020
    127
    306
    edge of the Mt. Hood national forest
    I'm pretty happy with how my Origin 20 sounds by itself (you know like a Plexi on a budget) but I use an OCD and an SD-1 sometimes. The OCD on the LP setting and gain pretty low just gives it a boost, like I had hoped the boost on the amp would. The SD-1 to put some mid stank on it.
  19. Ninjaking67
    Ninjaking67 New Member
    May 4, 2020
    7
    16
    Don’t discount the Marshall pedals. I really like the JH-1 Jackhammer on the OD setting for my driven Marshall tones. One big plus - not boutique so therefore not expensive!
  20. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    6,594
    7,810
    Montreal
