What pedal do you boost your amp with?
Discussion in 'The Tone Zone' started by Alligatorbling, Jul 20, 2020.
  1. Neptical
    Neptical Well-Known Member
    Jun 13, 2010
    417
    890
    Transylvania
    For quite some time now I've been using a MXR M108s 10 Band EQ (with the Volume and Gain). It's a fantastic tone sculpting machine. Works great in the loop or out front just before the amp. I also have a Boss SD-1 (a favorite) and a TC Mini Spark that arent on the board at the moment.
  2. Matthews Guitars
    3,739
    5,642
    I use a Seymour Duncan Pickup Booster. Set to not much more than 12 dB boost. Beyond that level of boost, the 1959's tone starts to suffer a bit.
  3. Kolanti
    Kolanti Well-Known Member
    Dec 9, 2019
    195
    268
    for rock and heavy metal:
    Boss SD-1
    MXR Super Dist+ Scripted Logo
    for extreme metal:
    Boss Metalzone modded (i took out one transistor to be more transparent)
    Mitchell Pearrow and Sustainium like this.
  4. Kim Lucky Day
    Kim Lucky Day Well-Known Member Gold Supporting Member
    Aug 22, 2018
    349
    903
    I use a Spark boost to color my tone into the front end of the amp (SV20H). For a volume boost without coloring tone, I've been running a LPB-1 in the loop along with a JHS Little Black Box set to about 50%. This does a fantastic job of boosting volume without adding saturation.
    I just got a Solodallas Storm and it really adds a nice touch of compression that makes my leads sing even more than the LPB-1. I may just do a permanent replacement here, it's that good!
    Mitchell Pearrow and wntbtw like this.
  5. Marshall4Metal
    Marshall4Metal Well-Known Member
    Jul 28, 2016
    414
    517
    For fucking around at home at bedroom volume Digitech Death Metal. In a band my JCM900 an SD-1 with a chorus and reverb it covers everything from AC/DC to Autopsy.
  6. twangsta
    twangsta Active Member
    Dec 26, 2019
    99
    126
    I hear SD1 coming up quite a bit. I'm gonna reach for a waza version. Will it be very different from a DOD 250 style pedal?
    Playing a 1959.
  7. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,727
    1,809
    I had a Sunn "Beta Lead" back in the day, best SS amp I ever played. It was set up like the Mesa Fillmore, 2 of the same ch. which I like very much.
  8. Mitchell Pearrow
    13,474
    25,509
    I had 3 buddies that had those Beta leads, and they did sound great, they even worked great for bass.
    Our bassist used one in 81-83
  9. Ramo
    Ramo Well-Known Member
    Feb 13, 2019
    635
    1,415
    Mxr gt-od or boos sd1
    depending on song.
  10. ampeq
    Sep 14, 2017
    1,727
    1,809
    When I sold my Beta Lead to my drummer, he pulled the head out and used it to mic his drums for YEARS! It just kept going and going, should have kept that baby.
  11. Vesperado
    Vesperado Active Member
    May 24, 2011
    229
    104
    I use two EQ pedals as my primary boosts. The Yamaha GE-100 at 9V with my MFD pickups and the Biyang EQ7 at 9V for my high-output buckers. The Yamaha has a Raytheon 4559S opamp which is quite smooth, plays nice with SCs. The Biyang has got 4x RC4558D which gets quite the bite, great combo for pushing the amp's drive using buckers. If I need I stack my Maxon made TS9 at 9V into either/or for some thicker creamage. For a clean boost the EQ maybe ran at 15V. I could use any combination of dirt pedals/buffers as a boost but find these [EQ] pedals are superior for this type of application.
    One thing to consider is putting the EQ at the end of the pedal chain for various reasons: (1) avoid overloading the input on another pedal, especially if its vintage (2) avoid bottle-necking of the band-pass, (3) allows for the remediation of the signal's tone before hitting the amp. EQ pedals are winners on my board.
  12. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,318
    3,529
    Bay Area, CA
    I normally use Sonic Edge Thumbleweed or Ramble FX Marvel Drive....Now I kinda wanted to try a treble booster...
  13. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,180
    2,195
    If restricted to only one od then a tubescreamer no question
  14. vtrain
    vtrain Well-Known Member
    May 15, 2020
    204
    350
    Chicagoland
    When I need just a bit extra, I’m getting some great tones out of the Way Huge Conspiracy Theory into my Origin 20.
  15. chromeboy
    chromeboy Well-Known Member
    Jan 25, 2010
    625
    332
    San Bruno,CA
    I use an ocd pedal to give my rhythm channel a little extra . I use a jet city 50h and 100hdm heads both have tons of gain. So I set the crunch channel at 12 o'clock which gives me a little bit of an ac/dc sound and use the ocd to boost that a little. I use the overdrive channel for more metal sounds and since the sound is also great for solos I just use a boss ge-7 and run it flat and just up the volume and it boosts great for solos.
  16. AlvisX
    AlvisX Well-Known Member Gold Supporting Member
    May 31, 2011
    5,299
    11,158
    I-55 Corridor
    One of my favorites . I have two of 'em . Nowdays I mostly use them for some juice when Im sittin' in . I also use 'em for balancing output differences in my acoustic guitar pickups
    I still have my LPB-1 from teenage years too
    Watching a Maiden show from '81,I swear I saw an LPB-2 on the floor
    In use on my home pedalboard.....
  17. AlvisX
    May 31, 2011
    5,299
    11,158
    I-55 Corridor
    Ive not tried that one yet , but Ive been workin the sh*t outa the Spark Mini for the last 3-4 years
  18. zachman
    zachman Well-Known Member
    Feb 8, 2011
    6,886
    6,883
    Tone Mountain
    Man that thing looks like it just came out of the box. Really Clean. Mine looks rusted out now, but it works GREAT!
  19. stargazer76
    stargazer76 Active Member
    Mar 17, 2008
    305
    60
    Dallas, Texas
    Modified SD-1 and a modified DS-1 (Lynch mod)
    Two totally different textures and eq's.
  20. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    1,253
    1,131
    NJ
    I don't dedicate myself to just one pedal. I have lots of colors to paint with. Such as a germanium treble boost I made, a Maxon tubescreamer, Proco Rat, Supro Drive, etc.....but lately I've been lusting after an Earthquaker Devices Acapulco Gold. I hear this really works well with your guitar's knobs. Just turn the pedal up to 10 and use your guitar's controls as desired.
