What humbuckers sound the most like a single coil to you?
Discussion in 'The Tone Zone' started by Giovanni, Aug 3, 2020.
  1. houseofrock
    houseofrock Well-Known Member
    Jul 10, 2015
    1,086
    1,264
    Florida
    Maggot Brain likes this.
  2. South Park
    3,505
    3,049
    The strat and tele have different tone pots And tone caps not the same. The closed thing to single coil in a humbucker is the coil splitting the pick up. What makes the signal coil work is the thin neck on the strat
  3. ricksdisconnected
    Aug 11, 2019
    6,006
    9,211
  4. houseofrock
    Jul 10, 2015
    1,086
    1,264
    Florida
    There are enough typos in this to confuse me but I get your point. OP is going for a split coil sound on a humbucker.
    Not exactly a Strat sound but a good single coil tone.
  5. Dogs of Doom
    23,901
    28,353
  6. Maggot Brain
    Dec 13, 2011
    1,606
    3,223
    Seattle, Washington
    In my personal experience... P90s.
    They do have their own sound but to me it is almost a combo of single coil and humbucker qualities.
    I am sure there is something out there closer to a single coil but I like the middle ground the P90s provide.
  7. freefrog
    freefrog Member
    Oct 1, 2016
    41
    57
    Interestingly, JBE humbuckers rely largely on the same recipe than the L500's or SH13 mentioned in my previous post: no cover, no brass or nickel silver baseplate (but a fiber or plastic one) and thin blades instead of the usual screw poles / slugs... These choices are understandable : less metal > less eddy currents > higher Q factor while blades > more focused magnetic field... Hence the easier emulation of single coils with such rails/blades 'buckers (as soon as they are wired to exhibit the "proper" low inductance, of course).
    FWIW: an humble side note, just to share another slice of technical rambling... ;-)
    Dogs of Doom likes this.
  8. houseofrock
    Jul 10, 2015
    1,086
    1,264
    Florida
    There are also P94's. Humbucker sized version of the P90. No adapter needed.
  9. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,318
    3,530
    Bay Area, CA
    Also look into DiMarzio EJ Custom (Eric Johnson)... verty twangy for a bucker
