What cables do you use?
Discussion in 'The Tone Zone' started by Maggot Brain, Aug 29, 2020.
  1. Styles Bitchley
    Styles Bitchley New Member
    Dec 1, 2015
    4
    I have used Monster and a variety of cables. Monster is very reliable, but I found it dulled the response a little. I think your best bet is to find a cable you like, buy it in bulk and learn how to make your own. With decent ends, reliability should be good unless you step on them frequently. You can’t fix a break in the middle of the cable, but ends are easy to resolver.
  2. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    401
    631
    I'm interested in some coily cables lately. Might pick up the Hendrix signature ones
  3. caco58
    caco58 New Member
    Nov 14, 2014
    4
    Pay at least $20 for a cable. Live Wire are great for the price. The most important thing in a cord is the shielding. Crappy shielding can cause a wire to pick up interference and get noisy.
    Don't fall for the gold plated b.s.., it's not necessary.
    Alter likes this.
  4. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,731
    1,813
    Pig Hog with fat color coded ends for all speakers. For the guitar cable I use only cloth covered cables, by Pig Hog, so they don't crawl up your leg. I'v had great luck with them, no problems ever. (Waaaay better prices than some of the other brands to.)
  5. Rhinodriver
    Rhinodriver New Member
    Jan 17, 2016
    2
    I use different cables for different guitars. My primary cables from guitar to pedal board and pedal board to amp are an old set of Monster Jazz cables. For my Gibson ES, I use a Mogami Gold to the pedal board, and the same exit Monster Jazz to the amp. The pedal board is all Mogami Gold. I used to have George L’s but some of the connectors occasionally had issues, so I switched. The system is dead quiet, which is unusual for a 100 watt superlead. The biggest tone change occurred when switching power cables. I now use a Purple Haze from Cutthroat Audio in Coeur d’ Alene Idaho. The mids and highs really came alive with this power cable. The speaker cabinets connect to the amp via Monster cables.
  6. PaulHikeS2
    PaulHikeS2 Well-Known Member Gold Supporting Member
    Aug 3, 2020
    257
    564
    For cheap cables, I recommend GLS Audio. They are very good - I've tried several of the >$20 cables and they're the best. Tried Pig Hog once. It cuts out a little bit. For mid priced, I have used and liked Spectraflex. And I have one of those Vox coiled cables. I like it, but the L end does not fit into a recessed Telecaster jack.
  7. StratoMarshall
    StratoMarshall Well-Known Member Gold Supporting Member
    Mar 28, 2012
    3,126
    1,956
    Tidewater, Virginia
    Belden 8406 cable, switchcraft ends. Make 'em up myself.
    I've got cables that I made in the 70's for on the road use that are still in excellent condition physically and electrically!
    ProCo make good stuff too!
  8. guitronics
    guitronics New Member
    Dec 19, 2010
    16
    12
    I also make my own cables...from patch through Instrument cables...and mine are the best !!!!! LOL
  9. Darkburst
    Darkburst New Member
    Dec 13, 2017
    12
    22
    Mogami Gold is the best bang for the buck. I also use the Lava RetroCoil but it’s not as clear and how fidelity as Mogami.
  10. MonstersOfTheMidway
    May 1, 2008
    5,290
    3,141
    I use a variety of brands; most have turned out pretty good. My favorite is Spectraflex.
  11. HellRot
    HellRot Member
    Apr 1, 2010
    36
    8
    I use Swiss made cables by Vovox.
  12. J E H
    J E H Active Member
    Apr 4, 2018
    268
    110
    interesting subject. Decades of playing, I have seen a lot of cables come and go. I have a philosophy about cables -- if there is a problem, out they go. I have had cables basically destroy equipment more than once. My oldest cable, I purchased in 1977. It is a 10 foot orange colored with the basic screw in/off plugs. Still works great. I have many others that have been around a long time. They do require care - especially during "tear down" BOught a "cable tester" once. decided to test it. PLugged two seperate cords in -- NO continuity. The tester told me that the cord was great. The tester went back home to the store. (50.00--hard earned money) If there is any doubt, I carry an old tiny amp -- for testing. Crash test dummy. Bad cords can ruin your board, amp, effects, etc. I used to do the repairs -- have not done that in a long time. Step one -- look at the cord before purchase. If possible, open and review the solder joints. If there is ANY doubt = NOT. Still have some of the old basic gray cords from radio shack with enclosed ends. They all still work. The Monster and the Mogami and other high-end brands are also subject to failure, however, probably a little stronger. Go easy on the cords -- shorts can happen very quickly - devastating results. AND -- please play louder. YOur neighbors need it.
  13. TM1
    TM1 Member
    Dec 26, 2011
    45
    45
    Ventura, Cali
    I've used Evidence Audio for the last 19 years! Never an issue or problem at all! They have been around the world with me and on every stage I've played on. What drew me to them originally was their clarity and full range fidelity! I had used Monster, but had issues with the plugs coming loose, and when American Airlines lost/stole my bag with all of them in there, I said time to try something new...
    I found the Evidence Audio's and tried a couple others as well and the Evidence just had what I was looking for. Luckily I developed a great relationship with Tony Farenilla, the founder/owner/creator. I love that all the centre wires are solid copper and the cables are Not Microphonic like most others. A brilliant way to build a cable! But I love coil cables and Evidence doesn't make a coily, but he recommeded the Devine Audio ones as he felt that Gil's cables were the clearest and fullest coil's. I have a number of Vox coily's and they sound like a blanket was covering my amp.. Great if you want mud.. I think the biggest reason that we all wanted more Top End back in the Sixties was the crappy cables we all used.. Anyway, Evidence and Devine Audio get business. I've been playing for 55 years and have tried them all! Enjoy!!
  14. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    970
    853
    Cleveland, OH
    Fender Professional Series are good enough for me.
  15. marco_giampa23
    marco_giampa23 Well-Known Member
    Feb 11, 2020
    353
    372
    STRAYA
    Alot of people in AUS use hosa, love the stuff, ive never had them fail but my mate had the tip because a little loose and stop working but local store swapped it no questions asked, the jacks are great, i have 2 hosa cables some random cable i got at a music store that has regular neutrik ends, i find that on the regular neutrik cable ends the metal unscrews all the time, hosa stays put well
    No good, ends come loose, could use thread lock i guess, quality is great
    https://www.pedalpartsaustralia.com...d=1237&zenid=670f9e05360163eba4400d066bda7155
    love these
    https://www.amazon.com.au/Hosa-HGTR...ocphy=9071431&hvtargid=pla-439307715576&psc=1
    considering buying and soldering on afew of these, neutrik is quality stuff
    https://www.swamp.net.au/neutrik-np...JRPOLCAx0ekWD2nQe5K0dCQERa2w4o5kaAkKkEALw_wcB
  16. DBI5
    DBI5 Well-Known Member
    Jan 14, 2010
    875
    524
  17. shooto
    shooto Well-Known Member
    Oct 22, 2011
    2,014
    1,186
    Denver, CO
    I make my own cables
  18. DaDoc
    DaDoc Well-Known Member
    Oct 13, 2014
    4,064
    5,283
    Rancho Deluxe, 3rd stone from the sun
    George L's..Tried 'em once and was hooked!
    Their ad states that the most common comment they hear is "It sounds like someone took a blanket off my amp!" And that was exactly the reaction I had when I first tried them!
    What I DON'T like about them is how stiff they are and don't like to lay flat, and they like to tangle. I take a lot of cues from Eric Johnson when it comes to gear, that's where I first discovered George L's..But he apparently uses Alessandro's as well, I assume from the pedalboard to the guitar? But no way in hell am I paying several hundred dollars for a 20 ft. cable! :noplease:
    I would love to find an alternative cable for running between my guitar and pedalboard that sounds as good as the George L's and doesn't cost a king's ransom, but until I do I'll put up the quirks of George L's! :D
    It's kinda funny that there's so many here saying "I make my own!", since they're basically doing the same thing I do with George L's, only I don't solder, except for the plug on the cable that goes to the input on my guitar..I like the plugs with a built in on/off switch for that, and I have to solder those.
    Sean Christie likes this.
  19. HOT TUBES 70
    Oct 13, 2008
    11,256
    5,770
    Mogami has been my mainstay for years , but a few years back i custom built a pedal board snake using Digiflex and was very impressed with the sound & quality of it too .
  20. Dean Swindell
    Dean Swindell Well-Known Member
    Mar 12, 2017
    287
    267
    First off, the whole "gotta have monster cables " thing turned out to be a joke - I was there, I was in on it from the late 90s to the early 2ks, I was a test subject. returned several - actually paid extra for Monster Jazz. Until they diched the lifetime guarantee. It's very simple; gear that doesn't hold up is not good gear.
