What cables do you use?
Discussion in 'The Tone Zone' started by Maggot Brain, Aug 29, 2020.
  1. bullhead
    bullhead Active Member
    Oct 20, 2017
    120
    200
    Richmond, VA
    I bought Monster Cables years ago that still sound awesome. That’s what I use currently. I tried MXR cables out of curiosity. Noisy as hell in my rig. I definitely wouldn’t recommend them.
    Shawn Kawvey and Maggot Brain like this.
  2. dragonvalve
    dragonvalve Well-Known Member
    Jan 16, 2010
    762
    700
    I have Proco and Whirlwind cables I bought in the late 70's early 80's still going strong. Cables have an effect on tone so I use different kinds. George L bulk coax cable soldered to Switchcraft plugs, odds and ends I've collected over the years of cables.
    Fender reissued the coiled cord ala Hendrix so there's a source there if you like shunting spiky Strat tone as Jimi did.
    Canare 4 conductor wired to mono plugs. Mogami is good too.
    Canare L-4E6S wired star quad style. I use these for patch cords on a patchbay.
    lordquilton and Maggot Brain like this.
  3. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    1,976
    1,924
    Calgary, Canada
    I just recently put together a snake when I got an Fractal Audio FM3 beginning of June, as it's on the floor at my feet, so is the Line 6 Wireless is there as well, where before the Axe-Fx II and wireless sat in a rack, so I only needed short patch cables.
    Anyways, pandemic dictated, I bought three 25 foot Hosa cables off amazon for the 4CM setup, Honestly, the Hosa's add no noise floor, tips seem decent, no noticeable tone loss or gain. I am just using EQ and FX with the fractal most times, so, just saying, you don't need to spend copious amounts of coin for decent cables these days which is great.
    Maggot Brain likes this.
  4. Sapient
    Sapient Well-Known Member
    Mar 14, 2020
    1,256
    2,409
    Yes
    Any ones that look cool and have gold tips that look cool too.
    :metal:
    IOSEPHVS and Maggot Brain like this.
  5. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,618
    1,645
    house arrest
    Probably want to add; that if your gear is newer go with Nuetrik. For older and vintage go Switchcraft. This allows for best possible seating connection for signal path between gear..
  6. junk notes
    Dec 10, 2018
    1,618
    1,645
    house arrest
    Two good points by @Sapient and @dragonvalve.
    Gold plated or Brass preferred whenever possible or where you have an option. A better signal path.
    Choosing the right cable makes a huge and noticeable difference in audible highs. Very easy to discern if you have two different cable types on hand for comparison.
    Several members here have big rigs and run w/d/w/ configs with multiple and variable voltages, and need their setup noiseless as possible. YMMV
    Sapient likes this.
  7. Alter
    Alter Well-Known Member
    Jan 29, 2019
    136
    254
    I've read shady things about the Monster cables company so don't consider their stuff. (Namely them suing many businesses using the world monster, plus having a bit bigger tips on their cables so they mess with your stuff and then normal tips don't work).
    The one cable I've had break down (and on a gig of course :) ), was a top of the line Vovox (which was an excellent cable well worth its money as it sounded awesome). Gave up on $100 cables after that and use much cheaper ones now, and not the solderless ones as they were less dependable for me. Canare, Mogami and a few Fender tweed ones mostly.
    Still have a couple of George L that I only use cause I play my strat upside down and the tiny plug fits very well.
  8. SkyMonkey
    2,584
    3,350
    The 'Burbs
    I only have one Monster Cable that I use between the guitar and my pedalboard.
    All my others were 'Sound Control' cables I got from a UK guitar shop chain of the same name that went under 10+ years ago.
    They were fairly cheap at the time, but have never given a non-gigger like me any problems.
    I recently swapped out all the cables I use in my DSL40CR/Boss GT-100 5CM setup for Boss BIC braded cables.
    Too soon to tell if they are going to last a lifetime yet ;), but they are solid and I would recommend them for home use.
    Shawn Kawvey likes this.
  9. Maggot Brain
    Dec 13, 2011
    978
    1,656
    Seattle, Washington
    Cool input, dont see cable brands mentioned too often so it's nice to get an idea on what all of you are using.
    I hope Monster kept their quality standards because out of all my cables they are the only one I trust 100%. I have one of the Fender "Jimi" branded coil cords, I like curly cables and this one looked pretty thick and of decent quality but after about 2 months of use I get some pops and clicks if it moves around too much. My 10+ year old radio shack curly cable is dead silent, is thin and looks to be made fairly cheaply.
    I'll check some of these out.
  10. Kutt
    Kutt Well-Known Member Gold Supporting Member
    May 27, 2010
    1,325
    1,965
    Massachusetts, USA
    I also use CBI and Mogami. No complaints about any of the three, all come recommended.
  11. Midnight Blues
    Midnight Blues Well-Known Member
    Feb 21, 2011
    927
    936
    Monster. I use Fulltone patch cables for my board, but unfortunately, Mike doesn't make them anymore.
  12. daiku
    daiku Member
    Aug 30, 2018
    17
    46
    I use PRS Classics for instrument cables, and Monsters to connect effects and such to my amps.
  13. Biggin900s
    Biggin900s Member
    Apr 28, 2014
    12
    33
    Hills of NorthJersey
    Mogami and Lava George L’s some whirlwind cables Ive had for 30 years people love to step on cables a big no no. Good luck with the hunt
  14. tonycaster
    tonycaster Active Member
    Jun 1, 2020
    63
    147
    Sicily
    I use mogami 2524 with neutrik plugs from guit to 1st pedal, mogami 2524 with pancake plugs between pedals and monster from last pedal to amp for tue dry sound, then spectraflex for tue wet sound, no noise hiss crackle whatsoever
  15. obx351
    obx351 Active Member
    Oct 12, 2012
    95
    106
    I currently use Mogami Gold 25' that are godawful expensive but work well. We'll see if they are worth 2 to 3x the cost of a Guitar Center patch cord which seems to last 2 to 5 years.
  16. Bazal
    Bazal New Member
    May 11, 2016
    11
    2
    I use any cable that has a good screening to cut out any unwanted interference. I also like decent jack plugs. I use planet waves solderless from my guitar to my effects as this has a kill switch built in on the jack. Been using them for years and never had a problem. Actually every so often I re-cut the ends and screw them back together.
  17. Caffeinated
    Caffeinated New Member
    Jun 11, 2020
    14
    20
    Fender Deluxe braided cables seem to last well for me for knockabout. I reckon cable ends are determined by application. A guitar with a socket on the edge will probably kill straight jack cords quickly, for instance.
    Agree that Mogami is probably as far up the tree as I’d go.
    I tend to avoid Monster due to the plain dishonest stuff they flog to people buying AV kit in chainstores. I figure if their morals are low enough to try to flog £100 power strips and gold plated USB cables for similarly silly money I’m not interested in anything else they’re trying to shift.
  18. JvZ
    JvZ New Member
    Mar 25, 2014
    29
    13
    The Netherlands
    My own ..
    Made of Mogami cable and Neutrik plugs
  19. Marc Johnson
    Marc Johnson New Member
    Dec 8, 2016
    8
    Pig Hog everywhere but instrument > tuner.
  20. Spooky88
    Spooky88 New Member
    May 24, 2020
    14
    16
    I've purchased and used every cable manufacturer that sold retail from 1984-1998. That's when I started buying from GLS audio (formerly orange county speaker). I built my own patch cables from their kits and their cables are very good and inexpensive. Highly recommended.
