Weber Bias Rite Alert!!
Discussion in 'The Workbench' started by Lane Sparber, Aug 18, 2010.
  1. Australian
    Australian Green Beret Silver Supporting Member VIP Member
    Apr 20, 2009
    17,943
    9,936
    Here it their latest statement. I'm going to email them, and see if i can get a replacement unit. Or at least some assurance that my unit wont be damaged with normal usage within their guidelines.
    MANUFACTURING NOTE: As Weber re-releases the Bias Rite units, we have upgraded some of the components. However, in order to remain sensitive enough to provide accurate reading, some parts are still very delicate. DO NOT attempt to play your guitar while the Bias Rite adapters are inserted. Doing so may very well cause the current to exceed acceptable tolerance for some of the components and damage the unit. Remember, you are only using the Bias Rite to adjust the IDLE current, which means the current level when no signal is being put through the amp.
  2. Birk
    Birk New Member
    Mar 20, 2009
    75
    Norway
    So does it mean it's still safe to use biasrite?
    Never had any problems with mine...
  3. Marshall Mann
    Marshall Mann Well-Known Member
    Apr 13, 2010
    4,534
    1,490
    Hey, no offence but can some one be specific here? Other than making the statement "we hate Webber Bias Rite because", who has had a specific failure and what was it?
    Rob mentioned that he has had an issue with his Bias Rite failing the smoke test, but has anyone else had an issue? I have tested mine against the 1ohm resistor with a meter and found it to be very accurate, with no issues. And is some one advocating for playing a guitar through an amp while under bias tuning conditions (ie meter or probe still in the amp)???
  4. RiverRatt
    RiverRatt Well-Known Member VIP Member
    May 2, 2008
    8,610
    2,878
    Between Memphis and Nashville
    Yeah, I want to see what my amp is doing under load sometimes.
    I bought an Amp Head bias probe off eBay years ago, and it's never failed me once. I already had a nice meter and it was a hell of a lot cheaper than the Weber stuff.
  5. RobS
    RobS Well-Known Member
    Apr 19, 2009
    992
    278
    Melbourne - Australia
    When mine smoked I had no guitar plugged in. Just the amp on, vol and pre both on 0 and heard a crackle and saw the smoke rise.
    I thought it was the tube but it was definetly the adaptor.
    When I emailed Weber I told them that the probe was giving wierd readings prior to it failing. The probe was showing the Pv at 460 one second and then 520 the next so I'm sure that probe was faulty.
    I still have the tubes and they are working fine.
    I guess using a MMeter and doing the math keeps the brain ticking too so that's a good thing:lol:
  6. Australian
    Apr 20, 2009
    17,943
    9,936
    Do you think that your Bias rite may have been damaged another time when you had the guitar plugged in Rob? mine has been used about 10 times and works fine, and i've never had a guitar plugged in while biasing.
    Weber should offer a replacement to anyone who has had problems with their product.
  7. Marshall Mann
    Apr 13, 2010
    4,534
    1,490
    Hey Rob and River Rat,
    Thanks for the info! I have always been taught not to bias with the guitar plugged in.
    And I agree, making your self go through the exercise with a multi meter from time to time, not to mention making sure a tool like a bias meter is still with in tolerance, is important. But I like the convenience of a bias meter as well.
    I have used the Bias Rite for a few years now without any problems (not sure on the count, close to 100 times). It's clear that the build is not superior, but I am not dragging it around either.
    Injun Rick likes this.
  8. RobS
    Apr 19, 2009
    992
    278
    Aussie, I beleive mine was a genuine fault as I have the BR2 two head probe and probe A failed, probe B still works fine.
    When it failed the Vol & pre were both at 0 and no guitar plugged in. Just idling away for about 30minutes to allow for any temp changes.
    I was watching TV whilst it was idling, heard a crackle and then saw the smoke signal.
    As far as for guitar being plugged in, no.
    Rob
  9. Australian
    Apr 20, 2009
    17,943
    9,936
    Ok disgruntled Weber brothers, unfortunately tonight I join the club.
    Over the last few months, I've been checking with my Bias Rite but then also with DMM to make sure, and its been fine.
    But tonight the crazy readings were here in full bloom.
    First a probe read 10 while the other 20. Then I was getting readings around 100 for each probe. The Vp read at 482, then 5 mins later read about 600.
    Lucky for us the Techs here put up the warning signs in time.
    Has anyone been given a refund on these faulty units yet?
  10. Wilder Amplification
    Wilder Amplification New Member
    Oct 12, 2009
    6,163
    723
    Fresno, CA
    The only multimeter one would ever need - :D
    Fluke 189 multimeter
    Too bad this model has been discontinued though.
  11. MKB
    MKB Well-Known Member
    Jul 15, 2008
    1,268
    317
    We have several of these on the benches at work. I love'em, especially with the RS232 logging cable. GOOD bulletproof stuff. It is HARD to go wrong with a Fluke DMM.
    But here's my all time favorite: http://www.home.agilent.com/agilent/product.jspx?pn=34401A If that one doesn't rock your world, your world is unrockable.
