ToneWitch
This was built for a customer.
There are some things I’d like to point out that weber would not address with me through email. I have still yet to hear from them.
the chassis and cabinet are nice. Well the cabinet is nice-ish.
Problems:
The components -
Many of the components tested way out of tolerance mainly the caps. The resistors are fine. I replaced all caps with Mallory that tested out of tolerance.
The pots are the cheapest pots I have ever dealt with.
The pilot light arrived cracked and with the nut cross threaded on it.
The provided wiring was cloth style however, had no protection sleeve. I do not believe the wiring is rated for the voltage so I used my own known good wire.
The Chassis:
The output transformer cut outs were too small to facilitate the wiring (wiring would make contact with cutout. Had to drill holes and run wire through grommets.
The 2-part chassis connector holes are mis-aligned which makes it impossible to fit into the cabinet. I had to slot the holes in order to allow it to slide in.
The El84 valve holes were cut too small for the tube sockets. These had to be drilled out.
The Cabinet:
The built quality is ok. It looks nice but the box joints are loose.
Arrived without a back panel for output jacks. This is a head style unit. So now I have to make a panel. Also, no output jacks were provided.
I brought these issues to Weber’s attention so they may mitigate more quality control of their product. Although, this isn’t a build for a novice I still feel some of the issues could easily be addressed by the company.
In Short:
I attempted to talk the customer into upgrading the components. But in an effort to save money they wanted to use what weber sent them. In total about 24hrs of build time.
Personally the Cabinet and chassis are decent. If you want a Vox AC30 I would use the cabinet and chassis they provide and source everything else.
once I get the output panel built I’ll post some finished pics. Here is a gut shot.
Problems:
The components -
The Chassis:
The Cabinet:
In Short:
