Wavy cab build take 2
Discussion in 'Cabinets & Speakers' started by Geeze, Oct 2, 2021.
  1. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,973
    4,186
    Bottom section of BB glued in...
    I decided against the wavy bits on the baffle support. I needed it to blend with the dyed curly sublayer so curly maple it is...
    Cut the sides with a 2° slant on the backside. This time I cut them together to minimize flexure on the baffle...
    I glued in the bottom section before I realized I would need to dye the exposed section. Luckily that is fix able. The top and sides not so much so they were sanded to 220 and then dyed on the sublayer side. I haven't decided what I'll do with the front and sides surrounding the baffle.
    Top and bottom glued in...
    Russ
  2. Geeze
    Jul 25, 2015
    1,973
    4,186
    Side baffle supports glued in...
    A whoops with the dado blade to be repaired or at least made less noticeable...
    The top lines sorta match up - the bottoms will have to fend for themselves...
    Russ
    BlueX, Headache, Eric'45 and 4 others like this.
  3. fitz288
    fitz288 Well-Known Yinzer Gold Supporting Member
    Apr 7, 2020
    4,160
    10,682
    the Burgh
    Russ, dig a little more out of the boo-boo.
    If the top of the patch lines up, and the bottom goes to the end of the finger joint, no one will ever see it. :yesway:
    Eric'45 and Dogs of Doom like this.
  4. Geeze
    Jul 25, 2015
    1,973
    4,186
    Great idea! Unfortunately already glued.
    Working the bottom vine 'stubs'...
    Russ
    BlueX, Eric'45, Marcomel79 and 2 others like this.
  5. Geeze
    Jul 25, 2015
    1,973
    4,186
    Back in town from SC for some more fun.
    Bandsawed more curly for the 2nd side and top underlayer...
    Clampage...
    Some posed pics with the cab that began this foolishness...
    Russ
  6. fitz288
    Apr 7, 2020
    4,160
    10,682
    the Burgh
    Mmmmm. Clamp porn.
    I need some of those long reach clamps...
    Sapient likes this.
  7. Geeze
    Jul 25, 2015
    1,973
    4,186
    Best of all they are self adjusting - you can tweak the fine 'hold' but no more turning of the bolt. Just clamp 'em on.
    Russ
    fitz288 likes this.
  8. Geeze
    Jul 25, 2015
    1,973
    4,186
    Glued up curly maple sanded...
    Top cut to fit...
    Getting closer.
    Russ
  9. Eric'45
    Eric'45 Well-Known Member
    Oct 2, 2021
    321
    833
    Germany
    Just beautiful Geeze :)
    This is definitely one of my favourite Threads :thumbs:
    Geeze likes this.
  10. Geeze
    Jul 25, 2015
    1,973
    4,186
    Side sublayers cut to fit and sanded to 220...
    Dyed...
    Top sublayer glued in...
    Side layer...
    Internal intersection...
    Discovered I didn't have enough of the Bluesbreaker GC so ordered two more yards today from Mojotone.
    Russ
  11. Geeze
    Jul 25, 2015
    1,973
    4,186
    Sanding time - one of my favorites as the project begins to emerge from the chaos.
    First to deal with the faux fingers...
    Sanded...
    Other side rounded...
    All edges rounded...
    I plan on dyeing the baffle frame blue as well. I'm also pleased that the cab is square. The back side isn't all on one plane but I'm going to live with it.
    Russ
  12. Eric'45
    Oct 2, 2021
    321
    833
    Germany
    Ah yes, that has to be one of the most satisfying tasks of woodworking. :)
    Nothing like the thrill when you first see everything is flush, flat and tidy and you first get a glance of how the finished piece will look like.
    I like the blue color and I'm looking forward to the finished product :cheers:.
    Geeze and fitz288 like this.
  13. LRT#1
    LRT#1 Well-Known Member
    1,079
    1,748
    Nice work russ, i have followed through a few of your build over the years and they always turn out looking great. Looking foward to seeing this finished product
    Marcomel79, Geeze and fitz288 like this.
  14. Geeze
    Jul 25, 2015
    1,973
    4,186
    Rear panel supports...
    Baffle supports...
    Baffle...
    Russ
    BlueX, Eric'45, Marcomel79 and 3 others like this.
  15. Marcomel79
    Marcomel79 Well-Known Member
    May 3, 2021
    583
    730
    Oslo
    This is one of those threads were i keep going back to see if there are any updates. I cant wait to see and hear the final result. What speakers are you gonna put in it?
    Marco
    Eric'45 and Geeze like this.
  16. Geeze
    Jul 25, 2015
    1,973
    4,186
    EVM12L as I really like them for 1x12 cabs with 1959s and 2203s.
    Russ
    StingRay85 likes this.
  17. StingRay85
    StingRay85 Well-Known Member
    Aug 18, 2019
    1,921
    1,548
    Great choice, probably the best speaker ever made with this kind of power handling
  18. Marcomel79
    May 3, 2021
    583
    730
    Oslo
    I thought this was gonna be a 2x12...
  19. Geeze
    Jul 25, 2015
    1,973
    4,186
    The overall of the cab is 24" - I'd have to go much taller to accommodate that. The size is based on Zilla's Fat Baby 1x12. I built a walnut version last year and I prefer it to the TL806 cab EV designed for the EVM12L.
    Russ
    fitz288 likes this.
  20. Geeze
    Jul 25, 2015
    1,973
    4,186
    Baffle hole cut and sanded...
    Back cut and fitted...
    Now for some drilling and screw application and ripping an EV out of a cab.
    Russ
    BlueX, Headache, SkyMonkey and 2 others like this.
