Wavy cab build take 2
Geeze
Moment I'm trying to build my first Guitar...
I really understand the Part about selfmade Necks- That's what I'm struggling with currently:erk:!
I'm with you! I watched a buddy build two for a strat - the pretty one was unplayable the ugly one was marginal. Maybe someday.
Working on the transition on the corner to make the vine look correct one both sides...
Drawing the lines to cut on the bandsaw and shape with the oscillating...
Paduak side grain...
Glue up commences.
Russ
Geeze
Now that the ends where the finger joints are glued up I'm adding middle section vines. They certainly depict the randomness of nature. I'm going to tint the cross pieces made from sapele [the vertical vine wood] to differentiate them. Green looks dark and muddy on brown woods so something in an amber or orange are the current options. The sub layer will be tinted darker to separate it from the top layer.
I'm shaping arcs on the non wavy cross pieces to mimic the natural and I rigged up an easy way to hold the ends of a 36" rule to allow me to shape the middle for best look. Just two blocks with a saw cut the width or the rule and a couple clamps and I'm in the arc business. The grain of the maple, paduak and somewhat zebra wood will only 'work' with curves bent one way.
Lunchtime.
Russ
Geeze
Experimenting with dyes on the sapele cross vines, merlot...
Orange...
Amber...
Green, which after the brown wood slagging I gave it above I actually like...
Two of the top's cross vines were a bit short...
Here is the top trimmed up and the extensions being glued...
Was thinking about handle last night here is a ready made one on the top...
I'd need to build a tray of sorts under it to keep the cab closed.
Russ
Geeze
I'm also contemplating making the 3/8" sub layer from either wenge...
Or zebra dyed a bit darker...
Right now I'm leaning toward the zebra even though it's a squirmy wood when resawed thin.
As I near the 24+ hour mark I'm thinking more vines on the sub layer is more nutbag than I'm willing to invest. My attention span is limited I have lots of design elements to solve and the thought of adding more is daunting. Of course talk to me tomorrow and I probably yell BANZAI!!! and jump off the more complexity cliff.
Russ
Geeze
Last bits for the sides. The curly maple ready to cut...
Same bits cut, sanded to fit, curves drawn and sanded...
Experiment with green - funny how non bleached wood resists greens...
Next will be the nerve racking square up and all important 'line up' of the long vines as they 'wrap' around the corners.
Russ
Geeze
Squaring up the 3 sides so the alignment of the lateral vines kicked my ass last night. Rather than start a fire I decided to move on to the next experimental area.
The sublayer.
The current idea is zebrawood milled to .3125" and glued to form the backing layer. I'm going for natural random so here is book matched in a W...
Stacked semi randomly
Then the current idea is to mill in some 'in the distance' [smaller] vines to be seen in the gaps and filled with greenish/gray/black powders in epoxy.
Russ
Marcomel79
Oslo
The sublayer.
Russ
Wow man i cant wait to see the finished product. Thats one of the wildest things ive ever seen!
Geeze
First sublayer glued together...
Experimenting with milling vines in scrap zebra...
Dump in some 5 minute epoxy as I don't want to wait for the art grade stuff...
It's a pale green with some gold and silver for some sheen. I'll be looking for some more vibrant greens this weekend.
The Dremel and Stewmac router base with a 1/32" tapered bit.
Works well for Marshall and other logos I put on headshells but I may try a larger diameter as it's easier to get large sweeping curves in wood with big grain.
Russ
BlueX
Silver Supporting Member
Sweden
It's not enough to say I'm impressed. I really enjoy to follow this project. Fascinating to follow your thinking and creation.
Geeze
Still experimenting with the sub layer...
Going for dead trees in the foreground, dark on the sides with a bit of 'light' in the far distance. Trees first - milled in.
Filled with graphite black tinted epoxy.
Working with CA and accelerants has spoiled this impatient fool. I wish there was an epoxy 'hurry the !*$! up!!!!" spray.
Also - the zebra may be too busy for the effect I'm fumbling my way toward.
Russ
Geeze
After dealing with some health BS and building my own T bolts so I could cut at least one side of the three sides square...
Got a bit thin on the cross vine and had a FUBAR that should go away when I round the edges...
For grins I clamped the zebrawood sub layer - naked and semi colorized...
I'm thinking of turning the sub layer 90° to help differentiate it from the top layer.
On to the bottom and the front and back caps and fake fingers.
Russ
