Volume Vs. Tube Life
Discussion in 'Marshall Amps' started by BrentD, Dec 20, 2017.
  1. BrentD
    BrentD Active Member
    Jan 27, 2012
    594
    246
    Trying to make this hypotehtical, but I find my JTM sounds best with the channel volumes at 6/7 and 4. This is natural overdrive territory but I wouldn't consider it "cranked."
    We've all heard that running amps flat-out burns tubes faster than running them turned way down. But what about in the middle? Is it a linear relationship? Aside from anomalous tube failures, when is it no longer safe to just run the tubes that are in there? Is it best to change them at regular intervals (every year, every other year, etc.)?
    liontato likes this.
  2. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    2,103
    2,879
    Södertälje, Sweden
    Most people bias their tubes at 65-70% of max dissipation...so even at idle, with no sound, you're burning away tube life.. with signal, the tube will be off 30-40% of the time... don't worry about it.. there are new tubes to be bought and if you don't want to run them as intended, you might as well play solid state.
    J
  3. Crunchifyable
    Crunchifyable Well-Known Member
    Oct 28, 2011
    693
    372
    Georgialina, USA
    It depends on how you feel about the money for tubes and the stress on the other components.
    A master volume might save you money in the long run. And your hearing if you aren't attenuating.
    It sounds like a very loud volume, above band volume maybe. But on some amps, you just gotta crank em up for the magic.
    It's safe but the tubes aren't going to last forever. I think an amp that never sees volume can have the tubes last indefinitely (decades or more). If you're playing it at gigging volumes (or above) then maybe 6months to 2 years based on hours of use. You may know it when they are worn out, or you may not.
    liontato, BrentD and Len like this.
  4. Jr Deluxe
    Jr Deluxe Well-Known Member
    Sep 12, 2017
    274
    277
    Fenders are biased very cold like 50% mdp. Tubes have lasted for decades in some old fenderz. even played loud. EL34s arent known as durable tubes and people like to push them to get that marshall drive. That burns the tubes up in say 600 hours. Back the bias off to about the low 60s to make your tubes last longer. Moderate volume in the middle range like between 3 and 7 probably doesnt hurt the tube life one bit. Its winding out plexis biased hot that kills tubes. If you jam a couplr hours every night on a wound out plexi be prepared to change tubes about every 6 months.
    BrentD and Crunchifyable like this.
  5. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,475
    770
    Netherlands
    +1 on Johan. b
    Read up on the website of Randall Aiken tech section 'why bias at 70%'.
    in short... cranking an amp make life easy on the tubes..allthough counter intuitive..
    BrentD likes this.
  6. tschrama
    May 15, 2010
    1,475
    770
    Netherlands
  7. Jr Deluxe
    Sep 12, 2017
    274
    277
    BrentD likes this.
  8. Jethro Rocker
    10,259
    15,791
    Given the generally average tube life of 5000 to 10000 hours, which can be found in many places, it would take years to burn up a set of tubes. To kill a set in 2 years would be about 7 hours a day even at the lower end of tube life spectrum.
    Just play 'em.
    Rokinroller and BrentD like this.
  9. Crunchifyable
    Oct 28, 2011
    693
    372
    Georgialina, USA
    Not just Fender...Mesa...Peavey...Traynor (Yorkville sound era), etc, are well known to be biased cold. Not necessarily 50%, but enough to have crossover distortion. Which is another topic.
    But suffice to say there is merit to the idea that cold bias makes tubes last longer.
    BrentD likes this.
  10. Jr Deluxe
    Sep 12, 2017
    274
    277
    True dat. And just for the record i posted that many fenders are found biased around 50%. My personal recomendation was for the low 60s. My 4104 is about 65% . It sounds good there so i left it there. When it gets hot it probably drifts up to 70%. If you bias higher than 70% what happens when your tubes get hot? You drift into territory i dont want my old amps going into.
    BrentD likes this.
  11. JeffMcLeod
    JeffMcLeod Well-Known Member Gold Supporting Member
    Sep 28, 2017
    2,137
    3,479
    Don't bias your tubes to get more life out of them, bias your tubes to get the sound you want. If they last 5 years, so be it. If they last 5 months, so be it. You got the sound you want.
    If you're trying to avoid spending money on new tubes, this forum has a Classified section down towards the bottom. I'm sure your JTM will sell in no time.
  12. BrentD
    Jan 27, 2012
    594
    246
    Ouch! Really, I'm just asking in the abstract because people don't seem to play these on "5" - it's either bedroom volume or all the way up. Curiosity made me wonder what happens in the middle.
    :cheers:
    P.S. - It is a bigger issue if people play to failure and the tube takes out other components with it.
  13. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    1,012
    566
    Where'd you get those numbers?!? In my experience, no way... I'd say 1000-2000 hours, especially for power tubes; and that is probably being on the optimistic side.
  14. Jethro Rocker
    10,259
    15,791
    I saw something on here the other day quoting Randall Smith. Others too. Seems to be in the 5000 hrs for power tubes. Obviously mileage varies.
    At 1000 hrs, it's still an hour and a half EVERY day for 2 years to kill a set. I'll look for the other thread. If you play out for 3 hours every 2 weeks and practice for 2 twice a week, it still gives you all of 4 years.
    Here's from a Hughes and Kettner blog
    "You can expect a conventional amplifier tube to have a service life ranging up to 10,000 hours."
    http://blog.hughes-and-kettner.com/does-it-pay-to-regularly-swap-tubes/
  15. tschrama
    May 15, 2010
    1,475
    770
    Netherlands
    5000 to 20.000 hours.. quoting Peter Diezel
    Jethro Rocker likes this.
  16. tschrama
    May 15, 2010
    1,475
    770
    Netherlands
    read the Randall Aiken paper... then you ll know what happens in tje middle.
  17. Jethro Rocker
    10,259
    15,791
    Even if its 2000 or 3000, that's an ass load of playing. I certainly wouldn't regularly change mine at a certain age.
  18. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,761
    1,354
    UK
    People worry far to much about valve life, in my opinion, and replace them unnecessarily....
    I've seen 10,000 hours quoted for an EL34, but even if it was half this, assuming you play for (say) 4 hours a week, practices and gigs, that gives you 24 years!
    I think this is about right. I have a 1980 2203 still on its original valves (pre-amp and power), and a 2009 JVM410 with original power valves, but I only ever use either of these amps for full band practices or gigs. (At home I use an AVT20 through a 4 x 12 Cab, which gives a better sound for home practice anyway!)
    Rokinroller and Jethro Rocker like this.
  19. Jr Deluxe
    Sep 12, 2017
    274
    277
  20. danfrank
    Mar 5, 2015
    1,012
    566
    Yes, I agree with you on this. Even 1000 hours, like you calculated it above, is a long time of use.
