Volume issues on DSL 100 clean channel
Discussion in 'The Workbench' started by Mike Loiseau, Aug 2, 2020 at 4:14 PM.
  1. Mike Loiseau
    Mike Loiseau New Member
    Jun 22, 2017
    9
    2
    Hey Everyone,
    I have a DSL 100 that has volume issues on the green channel clean, let me describe.
    I'll turn on the amp and let it warm up for 5 min or so, I'll play the green channel clean without a problem for 10 min, then the volume drops by half or more and fluctuates up and down, i'll push the crunch button and the volume often comes back, this goes on for 30 min then i can play for hours without any issues. this only happens on the green channel not the red. i changed all the tubes and checked bios but I'm still having the same problem. I almost suspect there is something loose or needs re soldering as sometimes pushing the crunch button doesn't get the volume back i'll give it a smack on the top and the volume comes back .
    Thanks in advance for any help in diagnosing this .
  2. anitoli
    anitoli Well-Known Member
    8,045
    9,766
    Sounds to me like a bad solder joint.
  3. Mike Loiseau
    Jun 22, 2017
    9
    2
    Ya i agree, sounds like a bad solder joint, but where I wonder...and how do i even start looking.
  4. pedecamp
    14,850
    12,022
    Try replacing a tube one at a time to see if theres a dodgy tube. Clean all your inputs, tube sockets and pots with Deoxit. :yesway:
