Vintage Modern problems
Discussion in 'Marshall Amps' started by rowanjvm, Jan 18, 2021.
  1. rowanjvm
    rowanjvm New Member
    Jan 18, 2021
    2
    Hi all, I have a 2266c Vintage Modern and every YouTube clip I watch it sounds nice and crunchy and full sounding but no matter what guitar I use it sounds shrill and the mid boost seems to do the opposite! Any ideas as to the cause?
  2. The Dose of Harmony
    The Dose of Harmony Well-Known Member Gold Supporting Member
    Nov 21, 2014
    826
    1,010
    Tubes Dude!
    I just got mine not even a month
    Maybe two weeks ago i replaced the pre amp tubes it was still sounding bad ass
    Three days ago I replaced the porwer tubes with JJ and it does not sounds as sweet as before!
    Looks like we have to put the original power tubes.
  3. rowanjvm
    rowanjvm New Member
    Jan 18, 2021
    2
    So it needs new OEM power tubes?
    Georgiatec likes this.
  4. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,320
    2,331
    Wilton NSW
    Hi @rowanjvm , I also have the same amp, I love it. Can you post all the knob and switch settings you are typically using there? For me, the key to getting a great tone was to get the MV up to at least 4, preferably 5 or 6.
  5. FracStrat
    FracStrat Well-Known Member Gold Supporting Member
    Jan 22, 2020
    612
    1,728
    Water Side of WA State
  6. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,082
    2,029
    You definitely need the master volume up on a VM as with any Marshall. Another tip , don’t use jj’s they are horrible .
  7. The Dose of Harmony
    Nov 21, 2014
    826
    1,010
    Man i read that the mullars too!
    That sucks
    I tried to buy the original but there havebeen sold out for a few weeks already!
    Old Punker likes this.
  8. Ufoscorpion
    May 4, 2013
    2,082
    2,029
    The original Marshall branded tubes are actually made by Shuguang so maybe see if you can get hold of those . Personally I put Electro Harmonix 6l6’s in mine and they sound great , I much prefer them to kt66’s.
  9. The Dose of Harmony
    Nov 21, 2014
    826
    1,010
    Yeah i tried to get those shuguang and nothing!
    And yeah JJ’s suck on the VM
    Trelwheen and Old Punker like this.
  10. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    1,326
    1,512
    Think the bias is very important on a VM,.............it can go from shrill to Pure Kossoff with a nice pair or quad of biased Gold Lions !
    Maggot Brain and FracStrat like this.
  11. Georgiatec
    Apr 23, 2010
    5,598
    5,112
    The amp seems to favour the Shuguang KT66. Although the Russian Genalex also sound good. You need to have a short plate ecc83 in V2 to keep the noise down in HDR.
    Old RFT's are plentiful, cheap and work the best, but a JJ will do in a pinch. Bias needs to be around 40mv per tube.
  12. JimiRules
    JimiRules Well-Known Member
    Feb 24, 2010
    2,946
    2,917
    When I bought my VM 2266 head it had Gold Lions. I replaced them with Shuguangs, I can't decide which I like better. To me the Gold Lions sound more creamy and the Shuguangs have more of an EL34 type crunch. This is at home volumes though. I pretty much dime the amp at gigs and the Shuguangs take on more of a creamy sound at higher volumes.
    Maggot Brain and Georgiatec like this.
  13. Stratmauler
    Stratmauler Member
    Dec 6, 2016
    32
    37
    My 2266C had Gold Lion PT's when I bought it. They were shot; shrill and rattly, and apparantly not that old.
    I bought a matched pair of Valve Arts KT66's from Amplified Parts, and no problems since. The amp sounds great, and no rattle. The Valve Arts are Shuguangs.
    I just had a quick look on Amplified Parts' website and it looks like they have some available.
  14. Georgiatec
    Apr 23, 2010
    5,598
    5,112
  15. Maggot Brain
    Dec 13, 2011
    1,172
    2,155
    Seattle, Washington
    2266H owner,
    Tubes are a good start, JJs sound fairly dark in the VM. I have Gold Lion KT66s power tubes biased at about 36mv-38mv each per spec.
    Make sure to start your tone foundation with the Body and Detail controls first then fine tune with the Bass, Mid and Treble etc.
  16. Mystic38
    Mystic38 Well-Known Member
    Oct 19, 2015
    348
    382
    If you have the master volume low, at bedroom levels then this is what it sounds like..
    Turn it up past 4
    VM tone is very sensitive to settings so stick with one guitar to start and Depending on guitar, but start with body setting 2 less than detail and work from there.
    if it sounds decent now, you simply need a bigger bedroom
    Maggot Brain likes this.
  17. JohnH
    May 31, 2008
    4,320
    2,331
    Wilton NSW
    If you find the tone, but its too loud for your use in the studio or at home, then you can consider an attenuator. If you'd like a project, the designs on our attenuator thread in the Workbench section, were developed specifically for this amp and will let you find the sweetspot at whatever volume you need.
