Vintage Modern Pilot Light Failures
Discussion in 'Marshall Amps' started by Wooferhead1, Jan 19, 2019.
  1. Wooferhead1
    Wooferhead1 Well-Known Member
    Jan 19, 2019
    524
    924
    Ohio
    I replaced the purple pilot light about a year and a half ago and it's burned out again. I'd like to replace it again but at $30 a shot is it worth the bother? I thought the problem was remedied with the newer led replacement ?
  2. Micky
    Apr 29, 2010
    21,091
    17,778
    Vermont
    Replace it with an LED...
  3. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,138
    2,071
    There's surely cheaper ways than a $30 bulb
    And it's certainly a rebadged off-the-shelf component that costs <$1 wholesale, and can probably be found for a couple bucks plus shipping retail somewhere online
  4. Wooferhead1
    Jan 19, 2019
    524
    924
    Ohio
    Isn't that what the purple light is ? or are you talking about an alternate version? I bought mine off ebay and it appeared to be a direct replacement - with the up-graded built in resister (which I thought was the fix for the original LED problems).
    tce63 likes this.
  5. Linedrive
    Linedrive New Member
    Dec 19, 2018
    11
  6. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    1,289
    1,424
    About time those are reasonably priced !.......they were like $34 on Evilbay where only one dude had them !
    I saw that Amplified parts have them also !
    tce63 likes this.
  7. 67mike
    67mike Well-Known Member
    Mar 5, 2015
    782
    887
    I was having that issue as well. I just soldered a resistor ( researched it and found suggested values which i forget)...this solves the problem..
    Kelia likes this.
  8. Kelia
    Feb 26, 2018
    1,289
    1,424
  9. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,908
    1,948
    Is this the same 6v lamp that Plexi's have? If so, the two reasons I do not replace with the LED, is one that they are indeed a LED and not incandescent, and that I do not have to wear sunglasses on an LED that is as bright as the Sun. It is "these" that break down more often and that it has a micro diode, just as filimant is prone to failing.
    Do yourself a huge laborious fave and track down an incandescent bulb version.
    [edit: type O]
  10. marshallmellowed
    Jun 26, 2009
    4,211
    5,766
    The "Purple" LED's do not last, not sure why. I never cared for the purple myself, so I replaced mine with a standard red LED, which should cost you less than $5, no issues.
  11. MajorMan
    MajorMan Member
    Nov 29, 2020
    30
    19
    You could solder a resistor to the pilot light like @67mike said. Or you change it to a different kind of pilot light. The current is to high so the light doesnt last that long. :shrug:
  12. marshallmellowed
    Jun 26, 2009
    4,211
    5,766
    There's a current limiting resistor built into the factory holder for the purple LED. I think it must have something to do with the composition of a "purple" LED that leads them to burn out prematurely, never had a red LED go bad. Just a guess.
  13. Thevenin
    Thevenin Well-Known Member Platinum Supporting Member
    Jan 19, 2019
    211
    419
    Austin, Tejas
  14. anitoli
    9,105
    11,997
    Looked at a few data sheets and i am seeing similar numbers for red, green, purple, yellow.
    Peak forward current 100 - 150 ma
    DC forward current ( operational ) 25 - 30 ma
    Peak Forward Voltage 2 -3.5 MAX.
    Can anyone measure what voltage is hitting a factory purple?
  15. Linedrive
    Dec 19, 2018
    11
    Soooo. Here's a real basic newbie kinda question. Would you wire the resistor in line with the purple wire going from light to pin 22. Or in line with the yellow wire going from light to pin 23? Or does it not matter? Or would you wire it a different way? Thanks!
  16. scott-colorado2016
    scott-colorado2016 Well-Known Member
    Jan 7, 2017
    265
    308
    Colorado, USA
    It doesn't matter which side you wire it onto, it will reduce the voltage to the led either way.
  17. marshallmellowed
    Jun 26, 2009
    4,211
    5,766
    If you're using an original replacement, it has a current limiting resistor built into the housing (LED holder). If you're modding it to use a different lamp, will you still be using an LED?
  18. gkterry
    gkterry Member
    Feb 27, 2015
    44
    73
    Most LEDs use a 2.2k to 3k resistor for a reasonable non-suntanning brightness. A low value resistor will be BRIGHT and short-lived. No resistor is a guarantee for an instant burnout of the LED.
  19. mickeydg5
    mickeydg5 Well-Known Member
    25,710
    12,732
    If using a 5V-6V LED go with replacing the stock 68 ohm inline resistor with a 330 ohm.
  20. marshallmellowed
    Jun 26, 2009
    4,211
    5,766
    I think the stock purple LED uses a 68 ohm resistor. They may have been trying to achieve a level of brightness out of the purple LED that was pushing it to it's limit, leading to premature failure. Just a guess.
    Maggot Brain likes this.
