Use a Tubescreamer! No, seriously, just do it!
Discussion in 'Other Amps' started by Adieu, Oct 8, 2020.
  1. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,042
    1,967
    So... wow. I had a Mesa F100 amp gathering dust unused that I bought on a whim a while back, didn't mesh with, and put up for sale.
    Found a buyer.
    Decided to plug it in to test everything works before the appointment, and just randomly plugged in through a Tube Screamer (which I somehow never tried before).
    And.... DAYUM!!!
    Boring bassy amp suddenly got SASS and bite, even at non-deafening volumes...
    Almost regret putting it up for sale now.
    jimmyjames likes this.
  2. Marshall Boogie
    Marshall Boogie Well-Known Member
    May 15, 2020
    309
    381
    Watertown, NY USA
    I would amend that statement to be try various drive pedals. Tubescreamers are in the medium gain range for drive pedals and I find that they are wayyyy too hot for most Mesa Amps (I have several types of tube screamer). I had to back off to a boost pedal to get the most out of my Mark V (really fell in love with TC Electronic Spark Boost). The Maxon ST9 Pro + was a seriously great pedal in front of my Marshall but the Mesa hated it (I would also state that you need a really good drive pedal with a Mesa because they are so very transparent any issues with the drive pedal will be magnified....for example the aforementioned Maxon pedal was glorious when paired with a Marshall but had this annoying wet/dry signal thing that became apparent when put in front of the Mesa...it was like everything played through it had two signals, one completely clean and one gainey....really annoying when you are just trying to up the gain)
    bblooz and Rusty Strings like this.
  3. Adieu
    Jan 12, 2013
    2,042
    1,967
    Too hot with drive 0 volume max? Or too hot to use the drive pot?
    scozz and Justin Whitstine like this.
  4. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,658
    4,317
    I love my f100, No pedals needed. 100 watt thump ,60 watt for leads
    scozz likes this.
  5. Adieu
    Jan 12, 2013
    2,042
    1,967
    Idk, the contour channel sounded like azz until I tried the tubescreamer knockoff into it
    Then it was pretty nice with high output pups
    ...still ended up selling it today, though. Too loud.
  6. anitoli
    8,720
    11,183
    NMV?
  7. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    2,066
    2,514
    West Oz
    Ya reckon tubescreamers are good, try treble boosters :cool:
  8. Adieu
    Jan 12, 2013
    2,042
    1,967
  9. Wildeman
    Wildeman Well-Known Member
    Oct 2, 2016
    1,974
    2,510
  10. Gunner64
    Gunner64 Well-Known Member Gold Supporting Member
    Nov 16, 2013
    6,464
    8,530
    Midwest, USA
    I have been using a tubescreamer for decades..not for the distortion, but the boost with the Drive down, level up. Work great and I have found the boost will help most amps sound tighter.
  11. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,346
    1,320
    I'v shown this before and it is still one of the best dirt & boost pedals ever. Of course they quite making it, but I think you can get it with the same drive and boost / drive with a comp. instead of the effects. The Katana side of the boost is just a level boost and only the level is settable. If you see a used one buy it, best single pedal you can own.
  12. MarshallDog
    Nov 28, 2010
    14,713
    16,060
    Taintville
    Ive had that happen when I sold a couple amps in the past, seems to work that out that way sometimes. I still sold the amps and have never regretted it.
  13. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,947
    1,822
    I always use a tube screamer a Marshall just doesn’t sound right without IMO .
    Gunner64 likes this.
  14. What?
    What? Well-Known Member
    May 17, 2018
    1,124
    970
    I generally like boosts more than tubescreamers. But a tubescreamer can be useful on a bassy amp to help roll off some of the low end and push the mids a bit. To my mind, a switchable straight up clean boost and tubescreamer should be housed in the same pedal with some eq control, since they already have alot of the same sort of circuitry anyway.
    Jethro Rocker likes this.
  15. Marshall Boogie
    May 15, 2020
    309
    381
    Watertown, NY USA
    Essentially anything stronger than a mild boost like the spark for some reason sounds like garbage even with the gain at 0(YMMV, my Mark V sounded bad with any pedal from Maxon ST9pro+ to Wampler Sovereign and even just for giggles tried the MXR distortion +, MXR Fullbore Metal, Mesa Throttle Box, Mesa Flux Drive, Big Muff Pi and Krank Krankshaft). The only one to approach being usable was the Spark Boost. (I tried to love these pedals with the V, just couldn't)
  16. Ufoscorpion
    May 4, 2013
    1,947
    1,822
    Many ( maybe most ) great hard rock tones that are so revered are guitar( strat, lp, sg whatever ) -tube screamer-Marshall , simple as that .
    South Park and Gunner64 like this.
  17. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    813
    944
    Ohio
    No thank you. I bought one years ago only to take it back for store credit.
    Just say "No," to solid state distortion.
    noxover likes this.
  18. Gunner64
    Nov 16, 2013
    6,464
    8,530
    Midwest, USA
    Yep. I clean boost eveything with a ts9, from 4 holers to Dsls..they all benifit from a goose in the front end. Proper Marshalls need a boost. Been that way forever..ask the Rangemaster users of yore..:D
    Just to be clear..I use the ts9 for its clean boost properties, which I like, drive down level up...not for it's drive up distortion.
    Jethro Rocker, Adieu and Ufoscorpion like this.
  19. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,766
    1,816
    perpetual house arrest
    JCM800 2203/4 + Ibanez tube screamer TS-9/808 or Boss overdrive OD/SD-1 = :flex:
    Ufoscorpion likes this.
  20. Justin Whitstine
    Justin Whitstine Member
    Sep 3, 2018
    38
    28
    there are lots of pedals you can use that cut bass / boost volume. They all cut bass to different degrees. There are the ones I use / know of.
    Tubescreamer
    Boss SD-1 super overdrive
    treble booster is freaking magic
    Boss blues driver
    Klon
    treble booster sounds similar to a blue driver until your guitar volume is at 10, then it gets really aggressive like a fuzz.
