Upgrade(again) or Burn my Mg
Discussion in 'Marshall Amps' started by Roag Jones, Aug 15, 2020.
New speakers or better cab
  1. Vintage 30s
    5 vote(s)
    83.3%
  2. Greenbacks
    1 vote(s)
    16.7%
  3. Marshall mx
    0 vote(s)
    0.0%
  4. Blackstar
    0 vote(s)
    0.0%
  1. Roag Jones
    Roag Jones Active Member
    Jul 31, 2019
    81
    103
    Hello guys I know everyone hates an Mg, but I love it's size, I'm old fits in the Jeep better. I play through a dsl20Hr or a Blackstar club50. My Marshall has 4 ohm Jensens. I've used the 412 for years, but recently acquired a 212 verticle Harley Benton with vin30s. It's apparent that both Amps sound tons better with the vi30s.....is it worth upgraded my beat up mg.....I know the common answer will be buy a better used cab, but I live in the middle of nowhere northern New York and that is not an option iether.
  2. Dogs of Doom
    23,838
    28,202
    sure it's an option...
  3. Mitchell Pearrow
    13,468
    25,475
    I put better speakers in a couple of my MG 412 cabs, so that’s what I do.
    Your ears will tell you what you like.
    Cheers
    Mitch
  4. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,688
    2,977
    Ft.WorthTX
    I’d seal off 2 ports and make it a 2x12. Install a couple WGS veteran 30’s. Best bang for your buck. Those small cabs are better sized for 2 speakers imo.
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,346
    2,119
    Sure, upgrade it but 4 V30's will probably set you back close to $500. Is finding a used JCM800 4X12 cab an option? I've played my 2X12 V30 cab next to my 4X12 G12T-75 cab and the G12T-75's were actually a little smoother sounding. FWIW you can find those cabs all day in the $500 to $600 range.... just a thought.
  6. RCM 800
    RCM 800 Well-Known Member
    Dec 20, 2019
    874
    1,755
    last time I looked Avatar had V30's on sale.
  7. Roag Jones
    Jul 31, 2019
    81
    103
    I'm def looking for a good used cab, but currently there's not much in the area.
    I am in the process of putting the Vin 30s on my 412(2 of them). And putting the mod 12/70sbin my 212 plywood cab
  8. Roag Jones
    Jul 31, 2019
    81
    103
    Trying that solution out!
  9. Sapient
    Sapient   Silver Supporting Member Platinum Supporting Member
    Mar 14, 2020
    2,553
    4,914
    Yes
    Where is the "Burn the MG" option?
    JK - :fever:
    Do what you would be happy with, in any case.
  10. Roag Jones
    Jul 31, 2019
    81
    103
    I put the 2 vintage 30s in the top as it's a slant cab, should I try x pattern. I'm quite happy with the 2 celestions in there.
  11. Iron1
    Iron1 Well-Known Member
    Aug 14, 2020
    246
    575
    Minne-SOO-ta
    I put Celestions in my MG110s and it made a HUGE difference. The stock ones were hot garbage.
  12. Dogs of Doom
    23,838
    28,202
    that's the Blackstar option...
  13. Bloodrock
    Aug 12, 2010
    2,688
    2,977
    Ft.WorthTX
    try one on top and one across on bottom and seal off the other holes with some plywood or whatever. Makes a great 2x12!
    Sustainium and Mitchell Pearrow like this.
  14. Iron1
    Aug 14, 2020
    246
    575
    Minne-SOO-ta
    Or leave one hole open, try that and then seal it to compare. Regardless, any Texan who loves Possessed should be listened to.
  15. Roag Jones
    Jul 31, 2019
    81
    103
    Yeah....The blackstar is going back.....it's great as long as I don't compare it to my dsl! Blackstar in nice a bedroom volume.....but given some time crank them both..... At high volume DSL thumps and screams...Blackstar gets noisy. DSL has spoiled me.....I'd like a bigger more powerful amp for bigger shows.....it's gonna have to be a bigger dsl
  16. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    2,626
    2,770
    Shakedown Street
    Load your cab with Vintage 30's . The ears don't lie .
  17. avspecialist
    avspecialist Active Member
    Mar 5, 2011
    103
    65
    Connecticut
    Hi Roag, the way you wrote your description is slingtly confusing to me. Are you saying you want to use new speakers in your cabinet. Is your MG a combo or a head cabinet? Your avatar shows a head/cabinet. Anyway I had a MG100HDFX as a single 12 cabinet with an eminence Swamp Thang, A single 4X12 MG cabinet then a full MG stack. Playing at home solo was ok, but I didn’t care for its sound and response to my playing that much no matter what I did. The main issue for me was it lacked low end and warmth and punch at any volume no matter what speakers I used. In a band setting it seemed fine since a lot of other instruments combined for a total sound. For me no matter what I did, I couldn’t get better sound than OK. I would probably leave it alone and not put a lot of money into it since I found even with $ 500.00 worth of speakers it didn’t really improve the sound that much. You might be better off finding a good deal on another amp.
  18. solarburnDSL50
    Aug 8, 2008
    17,590
    13,749
    Wetville
    Speakers can make or break an amp. Do it.
    I would use V series for that amp. I have great cabs and a few different speakers(GB'S, V30's, GB128's, Jenson Black, V series, 70/80)
  19. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,725
    1,808
    You can buy a brand new 2-12” cab from Eminence for $200, or they will load it with any of their speakers. I have one and they are very nice cabs but I like a V30 & 75w CB best.
  20. ampeq
    Sep 14, 2017
    1,725
    1,808
    Matches and marshmallows over here, are we car pooling?
    solarburnDSL50 and Sapient like this.
