BlueX
Sweden
After looking about and spending some time meditating on the porcelain throne the slot needs to be a chevron at 31° in keeping with the design
I like this idea (and that's the best place for ideas)
Geeze
Both drilled and cut
Edges rounded.
Not sure I like it but it was the best compromise vs. no handle.
Russ
fitz
Well-Known Yinzer
the Burgh
I think it looks better than just a slot - and indescribably better than a bolt-on aftermarket handle.
Functionality with style.
Once there's an amp in there and it's closed up, it'll just be a shadow in the pattern.
Geeze
Before I glued on the bottom bits, I sealed the center stripes and diagonals as I plan to dye the appropriate inside parts blue - don't know how well it will work but we shall see.
After the bottom parts were glued, I noticed an oops that required a .075" strip to fill in.
That's all for today. I plan to do some fitting of the rest of the bottom, the fake fingers then sanding.
Russ
Geeze
Proud finger joints sanded flat now for corner round. 3/8" witness lines drawn
40 grit orbital applied
Face plate in work. I hadn't planned on any blue bits on the front but the naked reality of amp chassis and mounting hardware changed my mind.
Most of the bottom will be cut off for the control slot but on the upside I don't have to cut additional cooling vents.
Russ
faerdi
This is by far the most interesting thread at the moment. Looks stunning so far. Can‘t wait to see the final result.
Geeze
I had a couple of unhappy bits on two of the diagonals and trimming for piping eliminated both - happy! Another unsung hero in my shop is a 'shooting' board used to straighten edges.
I cut and milled with width the maple piping which I typically attach with screws. In this instance it will make it easier to keep the piping white this way. I thought about red piping or blue piping but realized that white is the only one that borders both - so white it is!
Face plate posed tor glamour shot. I plan to use small steel brackets and neodymium magnets to hold it to the chassis.
I originally planned to trim the piping where it intersects the flag stripes but after looking at it I like the demarcation it presents.
What think you?
Russ
fitz
Well-Known Yinzer
the Burgh
What think you?
Yes - white "piping".
Looks wicked awesome, I can't wait for the blue to return...
I may have missed it if you mentioned earlier, but what's going in it?
BlueX
Sweden
What think you?
I love it! Great idea, and amazing work. Thanks again for the detailed pictures, it's a real pleasure to follow. The front looks great with the piping.
One question: how will you keep the blue stain from migrating over to the white/unstained parts?
