Unable To Remove Cover For 12ax7 Preamp Tube On Jcm 900
Discussion in 'The Workbench' started by 19rellimcm37, Aug 13, 2018.
  1. 19rellimcm37
    19rellimcm37 New Member
    Aug 13, 2018
    12
    Hello, first post here.
    I am trying to re-tube a Marshall JCM 900 Head with new tubes. I've run into a snag and don't know if anyone else has had this issue.
    I'm unable to remove the tube cover on one of the preamp tubes. For the other two, I just push down and turn counter-clockwise and it comes off. The one that I'm having issue with. I can turn it, when pushing down, however it won't come off.
    I worked at it and still can't get it.
    Was wondering if anyone else has had this issue and how they fixed it.
    thanks
  2. ampmadscientist
    17,865
    12,055
    Welcome to the forum.
  3. Micky
    Apr 29, 2010
    21,041
    17,686
    Vermont
    Try some De-Oxit. The kind with lubricant.
  4. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,684
    1,381
    Just look at it and make sure the nibs on the base are lined up with the grooves on the cover. Sometimes they seem like they won’t come off. Just pull. It’s thin aluminum.
  5. 19rellimcm37
    Aug 13, 2018
    12
    I don't have De-Oxit, however I do have a can of CRC QD Contact Cleaner, can I use that?
    Also where do I want to spray, if I can use this?
    I'm not sure what you mean by the nibs, are the the small round parts sticking out of the cap? I think I have them lined up, and I try to pull, however nothing...
  6. Mitchell Pearrow
    11,941
    21,422
    He He just a wee bit of overkill, don’t you think Ampmad
  7. Chris-in-LA
    Jul 19, 2018
    1,684
    1,381
    If it rotates it should pull off. Yes, those are the nibs.
  8. ampmadscientist
    17,865
    12,055
  9. Mitchell Pearrow
    11,941
    21,422
  10. Kutt
    Kutt Well-Known Member Gold Supporting Member
    May 27, 2010
    1,327
    1,977
    Massachusetts, USA
    Is it this style tube shield? If so, try to see if the "nub" / retainer I circled below is getting caught on something.
  11. mickeydg5
    mickeydg5 Well-Known Member
    25,059
    12,022
    If it is stuck because of rust/oxidation then loosen it up with one of these.
  12. 19rellimcm37
    Aug 13, 2018
    12
    I got it. I gave it a light spray of that contact cleaner and that seemed to do the job as it came off. I was going to post pics, but they are too big!
    thanks
    Micky likes this.
