Tube Recommendation For 2555x?
Discussion in 'The Workbench' started by JacksonCharvelAddict, Feb 27, 2018.
  1. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,655
    I have owned my 2555x for a couple years now and am curious about trying some different tubes. I have heard that the tubes Marshall uses are not very good. I am guessing that messing with the pre-amp tubes will probably make a bigger difference since I rarely run it past 6 or 7 on the master. ANyone have a tube combo they really like? I am looking to get a decent amount of bottom end and maybe something that does wel with high gain.
  2. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,265
    1,047
    Saginaw MI
    There really isn't a preamp tube that will improve bottom end...
    The stock preamp tubes were probably a JJ low microphonic in V1 and shuguangs in V2 & V3. ( Red lable JJ, white labels Shugs).
    They are not bad preamp tubes at all.
    Power tubes could be Tung Sol or JJ. Mine came with Tung Sol. I can tell you that the tung Sols sounded much fuller/ bigger than JJ EL34's.
    The jube doesn't have a cathode follower circuit so you can use any brand of 12ax7.
    I believe I am running Tung Sol in V1 & V2 and a Sovtek LPS in V3.
    Play with the bias. Sometimes cooler is better.
  3. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,768
    3,095
    Northeast, USA
    The power tubes do make a difference. I have not tried Ruby/Shuguang's in my 2555X yet, but I did roll through a few brands in my JCM 2000 and settled on them along with JJ preamps. I liked them enough to buy 2 sets of backup quads too.
    Ruby EL34BSTR
    :2c:
  4. wardal
    wardal Member
    Jan 30, 2015
    99
    66
    Ive been running a run of the mill gt 12ax7c in v1 and the shuguang that came in v2. I replaced v3 with a sovtek lps. For power tubes I've been running gt el34 m's with good results.
  5. Jethro Rocker
    10,259
    15,791
    I don't remember what was in my 2558 but I run an NOS Mullard in V1 and a Raytheon BP in the PI. Smooth. For more gain I still think the stock Shugs in V1.
  6. Kinkless Tetrode
    Aug 17, 2017
    1,776
    2,654
    + 1 on the Shugs in V1. Fat and creamy in my original
    Try the EH 6CA7 for more bottom.
  7. Jethro Rocker
    10,259
    15,791
    Maybe I should run the Mullard in V2 and put a Chinese in V1.
  8. Jethro Rocker
    10,259
    15,791
    Oops duplicate
  9. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,655
    Mine had tungsols in the power section. I know that when i received it the bias was way off. 85 on one side and 60 on the other. I tried putting them both to 70 as recommended made a big difference. Some people seem to like it biased at 73-75 but i didn't hear a difference.
  10. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,655
    Thanks for all the suggestions.
