TSL 122 strange sounds at louder volumes
Discussion in 'Marshall Amps' started by BobVigo, Sep 17, 2021.
  1. BobVigo
    BobVigo Member
    Sep 4, 2020
    58
    17
    Using the amp with my Mills Acoustics 4x12, not the internal 2x12s. Tried a different cab to rule out a speaker issue.
    It happens mostly on the lead channel - hear clip - but it’s also more prominent on the clean channel with the volume up.
    i swapped all but one preamp tube with good new JJ’s. I swapped the remaining with others I had and still the same issue.
    power tubes are new EHX. I added the stable bias mod maybe a few weeks ago. I haven’t checked the bias since I adjusted it after the install: could too hot of bias cause this?
    Any other suggestions as to what I should test and consider?
    https://www.dropbox.com/s/f0aaqrgzlndvwfk/TSL 122 strange sounds.m4a?dl=0
