TSL 100 / Never Again!!!
Discussion in 'Marshall Amps' started by triodeamplification, Mar 16, 2012.
  1. triodeamplification
    triodeamplification New Member
    Jun 28, 2010
    13
    I have had enough of the wonderful lack of customer support and the low down lemons that Marshall is building these days. I would have expected this from Fender but not Marshall. I paid a small fortune for a new TSL 100 10 years ago and to this day it sits in the closet because the main board was and has been acknowledged by Marshall them selves to be defective and conductive causing bias drift and other problems through out the main board. If they were in the US there would have been a Class Action Lawsuit over this amp and my $1,400.00 dollars i spent on this amp.
    As well the Marshall Haze is the latest in another amp that is prone to catching on fire and many of the board wire connections themselves are not made right. They make intermitant connection between the channels
    Marshall! The last great amp you ever made was the JCM 800. Everything MADE since including the JCM 900 is is some sorry work and solder baths that dont even get enough solder on the components to even stay together
    I have had my 2 cents worth because thats all Marshall amps today are worth. What ever amp you have now you wont be loving it so much after you realize that you really dont get much for your hard earned money
    What you will get is screwed/
  2. Söulcaster
    Söulcaster Well-Known Member VIP Member
    Oct 14, 2011
    9,158
    8,761
    Great Southern Land
    Fortunately my experiences with Marshall amps has been quite the opposite.
    Happy trails
  3. JTyson
    JTyson Active Member
    Dec 13, 2008
    225
    66
    1400.00?? YIKES !
    Hmm... I think you got screwed before you ever plugged it in..
    Sorry, I never cared for the TSL's tone, I flipped one after retubing and biasing it in less than a week for 800.00 that looked brand new. I do understand your frustration though. I'd never buy another one because there are other models that smoke 'em. Some of them are new ones :naughty: The JVM's kill the TSL's in every dept and have been stone reliable for me personally.
    Just sayin..
  4. Macro
    Macro Well-Known Member
    Jul 10, 2011
    2,549
    2,041
    The land of cheesesteaks and soft pretzels
    My TSL issues are well documented here, however they are limited to minor issues...and I only paid like $500 for mine. I've had other more reliable amps it they didn't sound as good. I tried....really tried to be a Boogie guy in the 90's....but when you play them for a decade then plug into a Marshall, the tone is undeniable.
  5. richieG
    richieG New Member
    Jul 12, 2009
    1,826
    953
    I agree the dsl and tsl problems were a joke and is a sour part of marshals history.
    Over here in Australia the fix was to get a new board and the cost of the replacement part was 800 bucks. Seriously.
    I agree the older amps were made better. But the new ones are really just a representation of price competitiveness. Trouble is the vast majority of people do not want to pay big bucks for an amp to be made the same as the old days
    At least marshals sound great.
  6. triodeamplification
    Jun 28, 2010
    13
    Well i had finally had to vent. Really Marshall should have honored and replaced those known bad boards. And as far as quality goes on any of the new amps there is so many errors in soldering. I mean if you work on them day after day then you get a better picture of whats really inside. Im not exagerating,i feel like im working on toys from walmart. That how bad the quality of the components and soldering is. Your amp tech will tell you the truth. He knows good made amps and cheap ones as far as build quality goes. These are all hybrid amps chock full of transistors anyway. None of them are all tube amps
    Adrian R likes this.
  7. Robert Arthur
    Robert Arthur Active Member
    Jul 26, 2011
    232
    56
    Indy
    I'm sad about yur experience, but my DSL has been a real soldier, and the new class 5 head has been apart by me just to know what it's about and roll tubes. The verdict? Nice piece of consumer instrument grade gear with cheap tubes initially. A real gem for $349. What gets me is 1 watt for $799, That's an amp issue I can't fix....
    jwebb1970 and Georgiatec like this.
  8. MonstersOfTheMidway
    May 1, 2008
    5,302
    3,166
    Too bad. I know that in the beginning of production, some of those TSL and DSL boards were down right shitty. Did you use your warranty to get Marshall to replace the board?
    If you are gonna buy a used TSL or DSL, you really gotta talk to Marshall and/or a very knowledgeable and trusted tech before you buy.
    Oh yeah, the DSL401 blows because it's effects loop only accepts rack gear (the signal is too hot coming out of the loop for stompboxes). You have to mod the loop in order to run stompboxes.
    medicjg likes this.
  9. DSL 50
    DSL 50 Active Member
    Mar 17, 2009
    271
    121
    Seattle
    Go buy a used one for $600
  10. Robert Arthur
    Jul 26, 2011
    232
    56
    Indy
    You can front load stomp boxes like any other amp. But I would never gig my 401, when I've got the JCM800. However, I gigged my Class 5 head/1922 cab combo last night for the first time. I'll be leaving that heavy JCM800 stack at home for a while....
  11. TheDon
    TheDon New Member
    Mar 10, 2012
    17
    2
    Wow, in 2000, my TSL 601 was in a fire then hosed down with water and still works fine to this day, other than having to replace a preamp tube a couple years back.
    Sorry to hear about your luck
  12. CAPDUNN
    CAPDUNN New Member
    Sep 9, 2010
    376
    129
    San Diego
    My 6100 has been a workhorse and I gig over 40 times a year, every year since the 1980's. When I bought my first 6100 back in 1992, I put the 800 in the closet and sold it a few years later because the 6100 was way better and much more versatile.
  13. diesect20022000
    diesect20022000 In Memorandum VIP Member
    Sep 5, 2010
    19,575
    7,205
    44076
    In my opinion the DSL100 MLB is the best of the DSL's if you're not tech savy. they're flimsier than the older models yes but they worked out the design kinks that caused issues all but the 8/4 gorunding issues anyway and that's something that will need done to every DSL out there if you use any impedance out other than the 16.
  14. jcm800gridlock
    jcm800gridlock Well-Known Member
    May 16, 2010
    1,800
    1,953
    Tampa, Fl. USA
    A nice TSL Head local Craigslist $300 minus tubes...
    Robert Arthur likes this.
  15. triodeamplification
    Jun 28, 2010
    13
    I sold that amp last night. That was the third one i have had. It sounded great but i had to replace the OT with a Magnetics Components OT. I kept the tubes and sold just the amp to a real great guy who is a pretty fantastic guitar player. Im using lower wattage amps to fill my head with these days
  16. big dooley
    big dooley Well-Known Member VIP Member
    Sep 2, 2008
    7,358
    2,898
    zeeland
    thank you for the "opinion" mr troll...
  17. diesel king
    diesel king New Member
    Nov 27, 2010
    1,071
    715
    UK
    I owned a DSL from new for 10 years and never had any problems, likewise my 2203KK has been good as gold
  18. diesect20022000
    Sep 5, 2010
    19,575
    7,205
    44076
    they're hit or miss. all three of my DSL100's had problems but they were all easily fixed by me or my tech for little money.
  19. LPMarshall hack
    Nov 18, 2009
    11,253
    11,764
    San Diego, CA
    I once tried to run my 900 over with a piece of large farm machinery. Broke the front axel...
    Roadburn and Söulcaster like this.
  20. 357mag
    357mag Member
    May 1, 2008
    320
    21
    I wouldn't call the poster a troll. He's upset at spending a lot of money and getting a faulty product. He's got the right to vent. Thing is if you say to yourself that you're not gonna play through Marshalls anymore and decide to switch to another amp, you lose your tone.
    There is no better amp than a Marshall if you're in the rock, hard rock, metal, and neoclassical genre.
