TSL 100 channel switching delay
Discussion in 'The Workbench' started by Parkerx02, Jul 12, 2020.
  1. Parkerx02
    Parkerx02 New Member
    Apr 22, 2015
    27
    Anyone know of what cap or resistor can be changed to get rid of the delay when switching channels? Im not talking about the reverb, but the actual channels. I had read that removing c39 on the lead channel board fixes this problem, but I removed c39, and nothing changed. Thanks!
  2. Vesperado
    Vesperado Member
    May 24, 2011
    83
    16
    Albuquerque, NM USA
    What revision (Issue Number) is your Lead board?
  3. South Park
    2,611
    2,101
    C39 has nothing to do with the switching the switching is done with a relay. You may have a relay going out
  4. Parkerx02
    Apr 22, 2015
    27
    It switches fine, just has a second or less pause. You can def hear the sound drop out momentarily. I had a Peavey Ultra Plus that did the same thing. I changed the value of a resistor and then had no drop in sound. Just wish I knew what that resistor was in the tsl. Looking at the schematic.. damn.. so complicated. Ive worked on and modded a lot of tube amps, and this one takes the cake for being overly complicated
  5. Parkerx02
    Apr 22, 2015
    27
    What does c39 on the lead board do? I cant find it on the schematic
  6. Vesperado
    Vesperado Member
    May 24, 2011
    83
    16
    Albuquerque, NM USA
    That would be C40 on the schematic. It's a little complicated. PM'd.
