Troubleshoot my JVM
Discussion in 'The Workbench' started by Hard40sta, Oct 18, 2020.
  1. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    I googled some old MF threads that say they were discontinued.
  2. avspecialist
    avspecialist Active Member
    Mar 5, 2011
    103
    65
    Connecticut
    I know I might be a little hot, I actually called The Tube Store told them my numbers, they thought they would be fine for their tubes. So far no red-plating, over the last month or so, just the best sound ever out of this amp.
  3. Jethro Rocker
    9,591
    13,597
    I got a Eurotubes bias meter. Same basic thing. Does 1 tube at a time. It was like 100 bucks. Shows PV and bias current. Still have to open up amp to adjust but hey, it's miles easier.
  4. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    Serious question tho...
    so if you have to open up the chassis and adjust the little bias thingy anyway...what is the benefit of it?
    Is it doing something else for you that a multimeter won’t? Just trying to figure out how these things work as opposed to the “traditional” way...:cheers:
    edit: I watched some videos and it looks like the thing does the plate voltage and milliamps equation for you. All you have to do is adjust the bias pot to the desired tube reading. Is that correct?
  5. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    663
    705
    Also, adjusting bias on one side affects the other. It's a balancing act to get both sides close to same DC millivolts.
  6. Geo
    Geo New Member
    Oct 2, 2020
    You have to find the balance yes,but the voltage on the plate what has to do with the tubes adjustment,even its going up or down,i don't get it..(sorry but im new to this,just bought my first tube amp and im on the same way)
  7. KraftyBob
    Sep 5, 2017
    1,900
    2,445
    Chicago Suburbs - USA
    I've not done this myself but figured it may be worth looking into for some.
  8. Shae201
    Dec 20, 2015
    663
    705
    If at all possible, take it to a technician and see if they will let you watch how they bias. There are important steps to prepare for biasing that you need to know. It can be dangerous. Learning to read a schematic and knowing how the power section works by having someone show you is a great start.
    Mitchell Pearrow, guitronics and Geo like this.
  9. Jethro Rocker
    9,591
    13,597
    It beats taking MM probes and touching live contacts on tube sockets firstly. Simply plug in, heat up, I still do tye math quickly but it measures the PV and current. Easy peasy,no MM, no poking atound inside with probes.
  10. anitoli
    9,383
    12,606
    I love the smell of arcing mulit meter probes in the morning...................:D
  11. anitoli
    9,383
    12,606
    That exposed voltage thingy could be very dangerous. I would rather use a meter inside the chassis.
  12. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    But you’re still poking around the bias pot correct?
    Hopefully they’ll stay selling those again soon.
  13. guitronics
    guitronics New Member
    Dec 19, 2010
    16
    12
    That is the best advice I have read...There were 3 guys quoting 3 different Bias voltages!
  14. Jethro Rocker
    9,591
    13,597
    Yeah. Relatively way safer to turn a small pot w a screwdriver though, to me, than connecting meters to live sockets. It elimates those steps. Totally worth it to me. Eurotubes likely still does.
    I like bias points and adjustments on the outside better still.
  15. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    I need to get one. I called them and they said they should be ready for sale again in about 2-3 weeks.
  16. Jethro Rocker
    9,591
    13,597
    I find it really easy. Esp when you have a few amps to bias here n there
  17. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    I also like that you can play the guitar while the thing is hooked up so you can tweak on the fly without disconnecting it.
  18. Jethro Rocker
    9,591
    13,597
    Good point. I have done that to set by ear but know I am in a safe area of bias.
  19. LPMarshall hack
    Nov 18, 2009
    11,199
    11,566
    San Diego, CA
    I know you know good tone, Jet. So if you like this bias thing, it’s good enough for me.
    Jethro Rocker likes this.
  20. Jethro Rocker
    9,591
    13,597
    Thanks! Well it is convenient.
    LPMarshall hack likes this.
