Trouble with my DSL40C
Discussion in 'Marshall Amps' started by Mike31533, Aug 2, 2020 at 1:27 PM.
Tags:
  1. Mike31533
    Mike31533 New Member
    Sunday
    7
    10
    My DSL40C has no sound. The only way to get any sound coming from it is plugging into the return jack on the effects loop. What could be wrong?
  2. SkyMonkey
    2,213
    2,801
    Relocated
    Can you see if any of the preamp tubes are dead (the 4 smaller ones).
    In a darkened room they should all have an orange glow.
  3. SkyMonkey
    2,213
    2,801
    Relocated
    Oh, and whilst your situation sucks, welcome to the MF anyhow @Mike31533 :welcome:
  4. pedecamp
    14,850
    12,022
    Check your fuses, check your tubes. Welcome to the forum. :yesway:
  5. Micky
    Apr 29, 2010
    20,978
    17,560
    Vermont
    Preamp tube, maybe a fuse?
    Is the sound wicked loud thru the FX return?
  6. Micky
    Apr 29, 2010
    20,978
    17,560
    Vermont
    Without more info it is hard to diagnose.
    One thing that can cause this is a preamp tube failure, or a problem with FS3, which is a slo-blo 1A fuse.
    FS3 is in the circuit that supplies the lo-voltage (regulated) to the main board. It also provides DC heater voltage for V1, a method to reduce noise in that preamp tube. I would look there first.
    If you are uncomfortable or unfamiliar with working on the chassis of an amp, then take it to a qualified tech.
  7. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,620
    8,181
    Welcome to The Marshall Forum @Mike31533. Lots of guys here with a wealth of information,......but they’ll need more info on what exactly is going on before they can help you out.
  8. Mitchell Pearrow
    11,046
    19,025
    :welcome: To the forum
    I have not read the entire thread but I can tell you that the problem is a bad preamp tube, if it’s already been addressed just skip my post .
    But take a known good preamp tube and check one at a time till you find the culprit, one of mine did this and this forum is where I read how to find the problem. And I did,
    Cheers to getting your amp back on its feet. They do kick ass.
    Mitch
  9. jeffb
    jeffb Well-Known Member
    Oct 11, 2011
    597
    973
    90% of the problems with tube amps, are the amp's tubes.
    Try rotating in known good pre-amp valves into V1-V4 until you find the culprit/s
    and fwiw- not all pre-amp tubes show/will glow significantly when running (as mentioned- use dark room)
    scozz, SkyMonkey and Mitchell Pearrow like this.
  10. Mike31533
    Sunday
    7
    10
    The tubes are all glowing.
  11. Mike31533
    Sunday
    7
    10
    No. There is sound but not very loud
  12. Mike31533
    Sunday
    7
    10
    I checked the fuses already. They seem fine.
  13. Micky
    Apr 29, 2010
    20,978
    17,560
    Vermont
    Checking a fuse requires a multimeter.
    Many fuses that 'seemed' fine to me were actually blown when tested.
    Pull them out and check them, especially FS3.
    Also put in your spare set of tubes one at a time
    to see if they are the culprit.
  14. Mike31533
    Sunday
    7
    10
    I'll replace the fuses and see if that works. That's the cheapest thing to do right now. There's no sense in taking it to the shop right now.
    Mitchell Pearrow and Micky like this.
  15. CraigerSS
    CraigerSS New Member
    Jun 10, 2017
    4
    12
    Try putting a patch cable between the send and return of the F/X loop. This will bypass the loop thus may eliminate f/x loop issues.
    Good Luck and welcome to MF.
    Mitchell Pearrow and Chris-in-LA like this.
  16. South Park
    2,639
    2,119
    Greetings from cal . Put some good tubes in the preamp if no sound send it to the tech . It may have other stuff that need to be looked at
  17. Mitchell Pearrow
    11,046
    19,025
    Do has Micky has said one at a time you will find the bad tube, when mine omits the same symptoms you are having, all tubes looked the same but one was not letting the sound through, I cannot remember which one it was but I did fix it with this simple test..
    Cheers
    Mitch
    Jethro Rocker likes this.
  18. Mike31533
    Sunday
    7
    10
    Thanks guys for all of your input. This is the first tube amp I've ever owned. I bought it used from a pawn shop locally for $150. I took a chance that it might be something that would be an easy fix.
  19. scozz
    Jul 20, 2008
    3,620
    8,181
    I hope it’s a quick fix for you @Mike31533.
    Welcome to The Marshall Forum! :thumb:
  20. Jethro Rocker
    8,307
    9,901
    I agree with most above. Try V1 or V4 preamp tube first. Well, all one at a time but my giess would be one o those.
    Oh and must add - I assume you are plugging guitar directly in? No effects, nothjng? Amd that guitar and cord work with another amp?
