Trouble with Marshall origin5
Discussion in 'Marshall Amps' started by Arkasha, Jan 22, 2021.
  1. Arkasha
    Arkasha New Member
    Jan 22, 2021
    6
    Hi there. I just bought this amp like 5 days ago. And there's the weird problem. After couples of connections it's working so strange. After I warmed that up there's no sound. After an hour the sound can return or still no sound. It's not problem with the cables I'm sure. But I'm very confused
    fitz288 likes this.
  2. pedecamp
    16,176
    14,544
    Return it and get another one.
    Mitchell Pearrow and Arkasha like this.
  3. fitz288
    fitz288 Apprentice Fermi's Paradox Analyst Silver Supporting Member
    Apr 7, 2020
    810
    1,629
    Pittsburgh, PA
    :welcome:
    If you just got it and are having intermittent problems, check for loose tubes, or pull them and reseat before you pack it back up.
  4. scozz
    Jul 20, 2008
    4,392
    9,956
    If it’s new then return it like my good buddy @pedecamp suggested.
    If that’s not the case, stick around and some of the more knowledgeable than me, will show up with some suggestions.
    :welcome: to The Marshall Forum.
  5. Arkasha
    Arkasha New Member
    Jan 22, 2021
    6
    Thank you all!
  6. Edgar Frog
    Edgar Frog Well-Known Member
    Sep 18, 2020
    189
    401
    Santa Carla, CA
    It's always good practice to check if tubes are seated properly before firing up for the 1st time. They can work loose from shipping and cause problems if loose and not tended to. All 3 preamp tubes were loose on my Origin 20H. Most people never consider to check even though it should be common practice/knowledge in the tube amp world. Definitely not always the case but I always wonder how many amps are returned for being "faulty" because of this.
    Mitchell Pearrow, Arkasha and fitz288 like this.
  7. South Park
    3,410
    2,936
    It sounds like a bad connection in the jacks input or out put . Bad cables will do this to
  8. Arkasha
    Arkasha New Member
    Jan 22, 2021
    6
    I've missed to turn off the fx loop on pedal and this happened. I'm feel me stupid. But it works now and I'm happy)
  9. fitz288
    Apr 7, 2020
    810
    1,629
    Pittsburgh, PA
    If you don't have any pedals in the loop, you can put in a jumper cable in case the footswitch gets turned on.
    Mitchell Pearrow and South Park like this.
  10. Mitchell Pearrow
    12,974
    24,179
    Welcome to the forum
    Glad you got it sorted out buddy
    :cheers:
    Mitch
