william vogel
- Joined
- Dec 18, 2016
- Messages
- 973
- Reaction score
- 1,167
I don’t know where you set the bass knob but most of us usually run it nearly on 0 maybe 1. If this is the case, you can swap in a 100k and still have plenty of adjustment. 0 on the 1Meg pot is theoretically 0 ohms. It’s used as a variable resistor vs a potentiometer so the fact that it is 0-1000000 ohms just means you get little to no adjustment range if 2 is the most you use. A much lower resistance would give you a better range of adjustment until you hit 0.Oh I see. I have a 500KL pot laying around so Ill try and sub that in for the 1meg.
For now, I have settled with the NFB at 16 ohms and the 33k resistor, it sounds much tighter. Do you suggest I get a 50+50 cap to replace the 32+32 to get a more tight low end?
