This is the sound in my head! What can get me there?
Discussion in 'Other Amps' started by ledvedder, Oct 19, 2020.
  1. ledvedder
    ledvedder Active Member
    Jan 13, 2011
    444
    121
    New Jersey
    I'm researching 15-20 watt amps that will give me that plexi classic rock, up to early EVH vibe. This particular one is a kit. Although I'm fairly competent with soldering, I'm not sure if I'm ready to build an amp from scratch.
    J Saw, Sustainium and tce63 like this.
  2. Kochens
    Kochens Member Silver Supporting Member
    Dec 28, 2013
    51
    40
    Copenhagen,DK
    At 3:16, was that part "Dizzy Mizz Lizzy" /Waterline danish band ?
  3. Kochens
    Dec 28, 2013
    51
    40
    Copenhagen,DK
  4. scozz
    Jul 20, 2008
    4,121
    9,218
    Hard to tell listening to a video, but that sounds like a Plexi with some added gain. You say you’re looking for this in a 15 or 20 watt amp,....I think a SV20 would be one to try.
    Do you have any experience with the Marshall Studio series?
    Possibly also the SC20, which is a medium gain Marshall, but I think the SV would be a better fit. I would start with those two though, they’re both 20 watts, and both are in the ballpark, tone wise, of the amp you posted.
  5. ledvedder
    Jan 13, 2011
    444
    121
    New Jersey
    I started my research quest with the SV20, but everyone says it's crazy loud, even at 5 watts. The SC20 sounds more like an 80s vibe to me.
    tce63 and Sustainium like this.
  6. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,737
    1,420
    That amp sounds pretty heavy, any Plexi style amp would have to really be cranked to sound like that without a distortion pedal, sounded closer to JCM800 territory to me. If you are able, I would play the SC20 and the SV20 side by side and see which one does it for you. By the way, what kit is that? I would like to check out the specs so that we could suggest why it sounds like it does.
  7. ledvedder
    Jan 13, 2011
    444
    121
    New Jersey
    Tube Town PX18, https://www.tube-town.net/ttstore/tt-kit-px18.html?language=en
    In the comments, it says that he gave it a Jose type mod.
    tce63 and BanditPanda like this.
  8. T.J.
    T.J. Active Member
    Mar 28, 2008
    105
    163
    ..... So it probably has an extra gain stage...
    South Park and scozz like this.
  9. Max Soler
    Max Soler New Member
    Oct 19, 2020
    Im trying to do a PPIVM volume on my JTM45+ from tubedepo ... It has what a believe is a pre phaseinverter MV and its just not enough gain ... I havwe a dual pot 250 pot but not quit sure how to wire it
  10. Chris-in-LA
    Jul 19, 2018
    1,737
    1,420
    You should post this in the Workbench as a separate thread.
    Kinkless Tetrode and Sustainium like this.
  11. Chris-in-LA
    Jul 19, 2018
    1,737
    1,420
    Follow OP’s link, it doesn’t appear to have an extra gain stage and no cascading either. There is something extra going on at V1. Maybe someone can explain what that is.
  12. ledvedder
    Jan 13, 2011
    444
    121
    New Jersey
  13. pedecamp
    15,618
    13,471
    I'd go with a Marshall Studio but depending on your budget if looking to save money Ceriatone makes the Son of Yeti and 2202 and 2525 for like half the price of the Marshall.
  14. marshallmellowed
    Jun 26, 2009
    4,112
    5,515
    The amp in your 1st post is modded (stated in the video title). To get that sound, you need to crank the amp up. I'd start with the SV20 and a good attenuator. From there, try adding some pedals. If that doesn't get you there (it should), you could look into modding the SV20 (cascade mod...). The one drawback to modding the SV20, is there are currently no schematics readily available.
    tce63 likes this.
  15. scozz
    Jul 20, 2008
    4,121
    9,218
    That's what it sounded like to me, that's why I mentioned the SC20.
    Kinkless Tetrode, tce63 and T.J. like this.
  16. ledvedder
    Jan 13, 2011
    444
    121
    New Jersey
    I originally started my research with the SV20, but I've read it's crazy loud, even on the 5 watt setting. I'd love to be able to get something that doesn't require an attenuator.
    tce63 likes this.
  17. T.J.
    T.J. Active Member
    Mar 28, 2008
    105
    163
    The SV20 is not a 50w amp which can get CRAZY LOUD .
    tce63 likes this.
  18. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    1,094
    2,245
    This amp sounds damn good, so good I had to crank up my SV20 for a quick tone comparison. I was instantly relieved as the SV easily holds its own. :lol:
    tce63 and WellBurnTheSky like this.
  19. Sustainium
    Oct 4, 2019
    1,094
    2,245
    :slash: Do you have a SV20? Many SV20 owners have not had experience with 50w amps and are shocked by the volume of the Studio Plexi.
  20. T.J.
    T.J. Active Member
    Mar 28, 2008
    105
    163
    Yes I have a Marshall SV20 as well a JMP 1972 50w.
