Discussion in 'Marshall Amps' started by Michael Roe, Jan 26, 2019.
  1. G the wildman
    G the wildman Well-Known Member
    Feb 7, 2016
    879
    1,197
    London UK
    Yes it was brown. Glad to have joined the Kettering club!
    purpleplexi and tce63 like this.
  2. wntbtw
    wntbtw Well-Known Member
    Nov 17, 2010
    507
    824
    Thank you for your reply--I was just curious with what your amp was doing wrong.
    tce63 likes this.
  3. wntbtw
    Nov 17, 2010
    507
    824
    Hmmm-any way you can call Marshall and ask them about your amp`s power tubes having to be biased, when you thought that your amp was cathode biased and therefore is self-biasing? Curious minds are curious about this! :)
  4. booh
    booh Member
    Apr 2, 2020
    19
    32
    There are resistors to regulate the screen grid voltage (as far as I know). Possibly a resistor was wrong or defective and had to be replaced.
    tce63 likes this.
  5. marshallmellowed
    Jun 26, 2009
    5,053
    7,952
    Probably just a generic form they fill out when an amp comes in. He may have just "checked" the bias to verify it was in range, and "checked" the "bias checked" box.
  6. G the wildman
    Feb 7, 2016
    879
    1,197
    London UK
    I appreciate the quest for knowledge in our community.
    But do not really want to bother them. Although, I am quite sure that they would respond if asked.
    Bottom line bloody great company and my amp is rocking.
    G
  7. Dogs of Doom
    25,830
    33,347
  8. marshallmellowed
    Jun 26, 2009
    5,053
    7,952
    When I see these videos, it reminds me of those that only ever use the upper left input and complain about it being overly bright, basically using only 1/2 the amp.
  9. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    1,305
    3,083
    What surprises me is hardly nobody talks about the top right and jump over to high treble. Use more normal channel with enough treble channel to give some top end. It was one of the first combinations i liked right off. Then i found out later Frampton set his plexi like that. If i use a boost pedal this is what i go with.
  10. Mark Collier
    Mark Collier Active Member
    Aug 8, 2019
    80
    177
    New Zealand
    Because I use mostly Tele's and my 2015 Gibson LP (all on the bright side of things) this is also how I run mine, mostly.
  11. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,890
    3,261
    I use a Y-cable for that.
  12. marshallmellowed
    Jun 26, 2009
    5,053
    7,952
    I use a "Y" cable also, but I think he's jumping the top 2 inputs, and plugging into the lower right (Normal Low), which will have a different result than using a "Y" cable.
  13. scozz
    Jul 20, 2008
    5,191
    12,084
    I haven’t seen too many guys doing that. I don’t own a Plexi so I’ve never actually tried it, how would you describe the overall tone Biff?
    tce63 likes this.
  14. junk notes
    Dec 10, 2018
    2,890
    3,261
    Oh, thanks.:yesway: :cool:yes, I have tried that at home on the 1959, IIRC when I have a fussy pedal hitting the front end, since there is no effects loop. I stick with the Y for the 1992 most the time, and for gigs.
    Looking forward to this weekend though, when I get the SV head. I will at least play it for a couple of weeks before it makes its transition into a Superbass. It will be nice having an effects loop handling some of the pedals that slam the front end.
  15. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,361
    2,433
    Is it much bother to convert it to superbass spec?
    tce63 likes this.
  16. Biff Maloy
    Mar 13, 2019
    1,305
    3,083
    Little more meat. Not as much gain.
  17. Biff Maloy
    Mar 13, 2019
    1,305
    3,083
    I've got a Y cable. Use that sometimes also. My point was an observation on jumpering. Truth is most of the time I'm high treble only, no boost pedals and cranked.
    junk notes and Mitchell Pearrow like this.
  18. junk notes
    Dec 10, 2018
    2,890
    3,261
    no Sir, not much bother with a little patience. That will go for me as well. Hopefully taking images along the way.:yesway:
    (I would not recommend this mod to a new and/or original SV, unless you are O.K. with resale. I am doing this to, and on, a previously owned used one)
    tce63 likes this.
  19. marshallmellowed
    Jun 26, 2009
    5,053
    7,952
    Just curious, what's the reasoning that this will make the SV20 a better amp than stock?
    tce63 likes this.
  20. junk notes
    Dec 10, 2018
    2,890
    3,261
    No, nothing to do with that. Marshall does not offer a 1992 in a Studio, only the 1959. The same reasoning goes behind players who prefer a Superbass 100 over the Superlead 100.
    Also, filtering would be seasoned to taste. I prefer lowered cans on the screens and mains, closer to the early 68 spec opposed to the 69/73-74.
    Just picked it up tonight!:woot: Looking forward to dialing it in.
