Discussion in 'Marshall Amps' started by Michael Roe, Jan 26, 2019.
  1. Kim Lucky Day
    Kim Lucky Day Well-Known Member Gold Supporting Member
    Aug 22, 2018
    406
    1,031
    If I could figure out how to get a usable lead volume boost out of it, this rig would be my go-to gig rig... Regardless, it's a lot of fun to play! Resized_20200314_165501(1)(1).jpeg
    dslman, Georgiatec, trovador and 9 others like this.
  2. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    4,295
    4,588
    detroit rock city
    That has to be loud
  3. marshallmellowed
    Jun 26, 2009
    5,141
    8,222
    Choke the volume down for rhythm (via loop), or an attenuator with a switchable boost are the only 2 ways I can think of.
  4. Mitchell Pearrow
    15,298
    30,407
    Welcome to the forum.
    Cheers
    Mitch
    tce63 and T.J. like this.
  5. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    2,069
    2,767
    Södertälje, Sweden
    ... the conundrum that built an industry...
  6. WellBurnTheSky
    Mar 23, 2019
    1,559
    3,627
    EQ pedal in the FX loop does the trick for me.
    Mitchell Pearrow, scozz and tce63 like this.
  7. Rimmme
    Rimmme New Member
    Mar 15, 2020
    8
    I know I'm a bit late to the game, but here's my lovely new friend. Guess, it's never too late for good gear :D
    Guitar is a 1990 Gibson Les Paul Classic. Absolutely love everything about this combination!
    Anyways.. thanks for all your posts in this forum! read almost every entry before I decided to buy the amp.
    Now there are two things on my mind:
    - the matching SV112 or the highly praised Barefaced cabs?
    - the new Two Notes Captor X for recording and playing at home since I live in a flat.. and you know what that means:rolleyes:
    What's your opinion?
  8. T.J.
    T.J. Active Member
    Mar 28, 2008
    108
    166
    Welcome aboard !!! Cheers ! ;)
    Rimmme likes this.
  9. tce63
    Aug 6, 2018
    2,170
    6,057
    Sweden
    Looks great, and :welcome: to the forum :cheers:
    Rimmme and T.J. like this.
  10. pedecamp
    18,012
    18,163
    Looks good! Put a boost in the loop for volume lead boost, I use an EHX LPB-1, cheap pedal to buy but works well in this loop. :yesway:
  11. Mitchell Pearrow
    15,298
    30,407
    :welcome: To the forum, nice rig and guitar , enjoy them in great health, when you get around to it, post some clips of your rig , I enjoy hearing my brother’s here on the forum’s rigs.
    Cheers Mitch
    Rimmme and tce63 like this.
  12. marco_giampa23
    marco_giampa23 Well-Known Member
    Feb 11, 2020
    353
    373
    STRAYA
    Anyone got any tips on checking out used amps? What to look for to check tube use, if caps are dying, stuff that will end up costing me in the futer pretty much?
    tce63 likes this.
  13. Kim Lucky Day
    Aug 22, 2018
    406
    1,031
    I have an LPB-1,as well and have tried it in the loop. It just saturates more without a noticeable volume boost.
    tce63 likes this.
  14. pedecamp
    18,012
    18,163
    Really? I have mine set at 9 oclock and I get a very noticeable volume boost in the loop. I'll tell you one thing, if you send your Weber back and have them add the footswitch option you will definitely hear a noticeable volume boost when you switch it off. Give us some detail how youre running your rig now.
    I'm just not understanding your situation based on my own experience with this amp. My setup is plug into the top treble channel input with the volume dimed to get low gain breakup, OD pedals out front for more gain and LPB-1 in loop for lead volume boost, and jhs in loop before LPB-1 for master volume. I've played this way at band volume and it works quite well. What volumes are you playing at? I know you use an attenuator too, I dont know how that affects your setup.
    dslman and BanditPanda like this.
  15. trovador
    trovador Well-Known Member
    Dec 10, 2012
    93
    271
    Boston
    That's a badass stack!
  16. marshallmellowed
    Jun 26, 2009
    5,141
    8,222
    In your first post, you didn't mention using a volume box before the boost pedal, that's the difference. Otherwise, you wouldn't be getting much of a volume boost. Also, I have a Weber with the "Bypass" option. The downside is, while it could work in the right situation, it completely bypasses the attenuator, so it would be too loud in most situations, even for soloing.
    tce63 and WellBurnTheSky like this.
  17. pedecamp
    18,012
    18,163
    Isnt that obvious, if youre going for volume you put it last not first right? :shrug:
    tce63 likes this.
  18. marshallmellowed
    Jun 26, 2009
    5,141
    8,222
    Not following. My point, was that you didn't mention the volume box at all in the first post, probably the difference between his setup and yours.
    tce63 likes this.
  19. pedecamp
    18,012
    18,163
    Like I said in my other post, I dont know what his setup looks like, I was describing my setup.
  20. marshallmellowed
    Jun 26, 2009
    5,141
    8,222
    Yes, I know that, but when you recommended using the LPB-1 In your first post to Kim Lucky Day, you left out the fact that you were also using a JHS volume box. Unless he is also using a volume box in the loop (in addition to the boost pedal), he won't get the same results. Just trying to clarify, nothing more.
