Jcm800 2204 compared to a SC20, interesting,....
Well I think @marshallmellowed nailed it. The biggest difference in the two is in the low end and punch. A 20 watt amp can’t be expected to keep up with a 50/100 watt amp in overall fullness and punch. But I think the SC20 does a great job and is fairly close to the 2204.Care to elaborate?
BP
I believe they both came with the domed top Marshall branded JJs. Mine currently have the flat top re-issue Mullard.Can someone that has both the SC20 and SV20 take a look at their output tubes. Both of mine have "Marshall" branded tubes, but the output tubes in my SV20 look like a JJ variant (domed vs. flat'ish on top).
I put the reissue Mullards in my SC20 too,...I believe they both came with the domed top Marshall branded JJs. Mine currently have the flat top re-issue Mullard.
Not me, are you thinking about doing it? It's curious that the SC20 and the SV20 have the smaller script while the Jubilee Studio has the larger script.Anyone replaced the Marshall logo on their SV20 or SC20 with a larger one?
I had seen a used one on ebay that someone had changed. I remember it looking pretty good, have to see if I can find a link to it.Not me, are you thinking about doing it? It's curious that the SC20 and the SV20 have the smaller script while the Jubilee Studio has the larger script.
I kinda like the smaller script on the smaller heads. The mini Jub has been out a number of years before it was incorporated in to the Studio line this year.
I don't know,....you don't think its a little too much?I had seen a used one on ebay that someone had changed. I remember it looking pretty good, have to see if I can find a link to it.
Here it is...
https://www.ebay.com/itm/Marshall-S...83.l10137.c10&nordt=true&rt=nc&orig_cvip=true
YeahI don't know,....you don't think its a little too much?
No, I've never done that, as I have two other non-master amps (1987x and JTM 45). Although it uses KT66's, the JTM 45, with a different bright cap, actually sounds closer to the 1959 than the 1987x.@marshallmellowed have you ever played your 1959 with 2 power tubes, if so did you hear a tone difference? Comparing that to your 1987x how do they compare? I never played a 1959 I read they are more open sounding than a 1987x. I did own a 1987x briefly and I liked it but it did have some compression to the tone I wasnt expecting. All I want is 50 watts, so I'm trying to decide if I were to get a full sized plexi to go for a 1959 and pull 2 tubes or 1987x.
How would you describe the tonal difference between the 1959 and 1987x?No, I've never done that, as I have two other non-master amps (1987x and JTM 45). Although it uses KT66's, the JTM 45, with a different bright cap, actually sounds closer to the 1959 than the 1987x.
