Marshall50w
Hi,
Recently bought a Studio Jubilee Head 2525H & 2536 Jubilee Cab. When using the Clean channel with the Output Master (at any volume) pulled I get no sound whatever the Input Gain is set at. If I pull the Input Gain (Rhythm Clip) I get a little intermittent guitar signal. The Lead channel Output Master pushed in seems to work fine as the Lead channel, with the LED indicator coming on.
In regards to the Clean channel, I have tried switch cleaning lubricant on the Output Master, Lead Master, Input Gain controls. I have also cleaned the input guitar jack hole plus the Effect Loop jack holes. I used a working spare ECC83 in each position, same with the EL34's. I have also swopped out all the original valves and used a full set of working valves, nothing has solved the problem.
Anyone had this sort of problem and any ideas how to resolve ?
Thanks.
Thanks.
