Hey guys. I am in the process of reading through this massive thread, so if this has been answered already, I am sorry.
Can anyone in the US tell the model number of the power transformer? Is it the same as the Origin or DSL 20s? Those 2 models are the same (TXMA-91073). I can't imagine Marshall is using too much of a variety of transformers.
I finally got a set of 6CA7s to try in my SC20, I know a bunch of you guys are using them. My tech recommended Electro Harmonix 6CA7s.
I only put them in a couple of hours ago, and I only had about 30 or 40 minutes playing. In that short time I can definitely hear a better, thicker low end and a kind of more focused tone.
I also may have noticed what a bit smoother, slightly less aggressiveness, not 100% on that though. But overall, after those few minutes, I really like them.
The whole reason I wanted to try these tubes was to get a little more low end, because I had heard from virtually everyone that tried them mentioning the better low end.
These tubes delivered on that, and it’s more than a subtle difference imo.![]()
Yes I’ve tried the gain dimed and it certainly does thicken it up, but that’s too much gain for my liking, and it’s a touch flubby and compressed for my taste.You've almost certainly noticed, but the last section of the gain dial really brings in the low end. If you want a thicker low end and a bit more clarity higher up try the gain dimed (even if you have to lower the input signal) and turn the presence up to a desired level...![]()
Hi and welcome to the forum!I have both an SC20h and a DSL20CR, they appear to have different transformers, but both are European models, so I can't really speak for the US models. If you have a look at the pics in my gallery you will find the gutshots of the SC20 (also in this thread, but ... 300+ pages) where I explicitely photographed every single number and code on the inside. A Google images search would probably do miracles, too - no luck there?
Nice, man!!Received my shiny new JCM800 Studio today. Took a little break from test driving it to snap this pic and share with you guys.
I don't know enough to know if what I'm doing is stupid (hopefully you will tell me if it is), but I pulled the trigger on a Euro-spec amp because of the killer price on Thomann before I fully thought about it and realized that its 230V/50Hz. For the record, the Thomann site does a very good job of telling you that information, I was apparently blinded by the prospect of a killer deal that I simply didn't see it.
That's why my first post here was asking about the power transformer. If I can simply swap it out, I will. In the meantime, I am running it through a step-up transformer. That sort of solves the 230V problem, but not the 50Hz problem.
Any thoughts?
If you try the workbench forum that's where all the super smart people mostly live. I'm very sure someone can answer youReceived my shiny new JCM800 Studio today. Took a little break from test driving it to snap this pic and share with you guys.
Any thoughts?
I have been using the 2 prong euro-spec cord because I thought I had to
I see what you mean. Chalk it up to my ignorance on the matter.Just to clarify in case anyone is confused. The eurospec plug the eurospec sc20 comes with IS a three prong...just that unlike a US spec plug, the ground is inverted (hole instead of prong).
Glad you got it worked out
Any thoughts?
Hi folks. This is my first post here.
I'm a new vc20 combo owner saw Caesar's post thought Id chime in.
I have not take deliver yet.
Caesar, sometimes a good technician can just re-configure the power transformer-as many amps use the same parts for both domestic and export products.
They do this to reduce costs.
They just use different taps which are the wires that come off the mower supply.
I was lucky one time years ago with an amp.
I cant find a schematic of this yet and
These new Marshalls; one of which I just purchased, I am not sure about.
But there is a good chance. I have seen this in Marshalls before.
A good tube amp tech should be able to offer a wiring mod solution.
Sometime it as simple as swapping two wires.
Sometimes they did not use the voltage selector switch and just blanked any extra lead off.
Its worth checking out if you haven't already.
Hope that may help.
Good luck.
Welcome and good luck with the combo!Hi folks. This is my first post here.
Hope that may help.
Good luck.
Hope that may help.
Good luck.
