The Official Marshall Studio Classic Thread Sc20
Discussion in 'Marshall Amps' started by scozz, Jan 26, 2019.
  1. markm
    markm Member
    Nov 10, 2011
    48
    47
    Hey all.
    Can we talk settings?
    Just curious where everyone has their preamp set to?
    And what you consider your core tone to be with that setting .
    I have never been this happy with an amp ever . And I do also have a JVM.
    Thanks
  2. marshallmellowed
    Jun 26, 2009
    5,179
    8,335
    I run my gain around 7, just before things start to compress and lose definition. I consider that level a good hard rock rhythm tone, which will still clean up with the guitar volume. This also depends on your guitar pickup output, I use 57 Classics, which are not a high output pickup.
  3. nkay
    nkay Active Member
    Aug 25, 2011
    172
    119
    Usually pres 6, bass 6-7, mids 4-6, treble 4, preamp gain 10, master (whatever I can get away with, depending if anyone’s home :dude:) goosed with an SD-1 or other overdrive, this is for metal.
  4. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    4,308
    4,612
    detroit rock city
    All on 7 pretty much presence 3
    markm, Mitchell Pearrow and GregM like this.
  5. PowerTube44
    PowerTube44 Well-Known Member
    Jun 23, 2014
    549
    947
    Any time I go to Guitar Center and check out a piece of new gear, and I decide to buy it, I always ask if they have a new one in the box. If they say no, then I'll order it online, from their website or elsewhere.
    Why? Because to me, that amp that's been beaten on by every 13-year old in town, or that guitar that's missing the whammy bar and the locking nuts, are NO LONGER NEW ITEMS. And, they don't discount anything as a "floor demo," even though that's very much what it is. If I'm paying the new price, I want NEW, not used. I've walked into pawn shops where the guitars were in better shape than the typical Guitar Center. Not kidding.
    Open box should be fine, though. That should mean that it's in a warehouse and ready to ship, not being toyed with by a thousand people.
  6. Mitchell Pearrow
    15,636
    31,512
    Congratulations on your new amp
    Stealth is looking good.
    Cheers
    wntbtw, markm, GregM and 1 other person like this.
  7. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,530
    2,827
    Pre amp at 10 o'clock for clean stuff, around 1 o'clock for most things and I dime it from some real hard crunch for blues and some rock 'n' roll. What I've noticed is that the presence and pre-amp seem to sound best balanced. The last bit of the pre amp dial really brings up the bass, but if you turn up the presence it gives you piercing lead with a solid bottom end. Likewise, when turning the pre-amp down, it's best to remove some presence, too before it sounds brittle.
    markm, GregM and Mitchell Pearrow like this.
  8. LCW
    LCW Well-Known Member
    Jan 18, 2017
    454
    887
    When boosting preamp 1:30-3 o’clock (depending on pedal and style)… metal baby!!!
    markm likes this.
  9. LCW
    Jan 18, 2017
    454
    887
    Has anyone swapped in 6550 tubes in their SC20??
    junk notes likes this.
  10. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    3,278
    3,909
    Was thinking about that.. I am looking for really good Marshall cleans. Less mids w/6550, but I will make that up somewhere in the chain. I had an amp that had a switch where you could swap tubes.
    IIRC should have better Marshall cleans, if that is the goal.
  11. SteelLucky
    SteelLucky Active Member
    Mar 14, 2016
    157
    178
    SC20H & SC212
    P4, B7, M4, T4, M3 to 5, Preamp 6
    GregM likes this.
  12. LCW
    Jan 18, 2017
    454
    887
    Aren't these Studios self biasing or cathode biased or something? Could a 6550 swap be as simple as just popping them in??
    Jethro Rocker and scozz like this.
  13. LCW
    Jan 18, 2017
    454
    887
    Presence - 4
    Bass - 6
    Mid - 4
    Treb - 4
    Master - 2
    Pre-Amp - 7
    I run either an SD-1 or TS-9 in front.
    markm likes this.
  14. junk notes
    Dec 10, 2018
    3,278
    3,909
    Yes, (I have the SV), but not sure on alternate tube, but I see people posting that it would be for replacement tubes of the same.
    I do not know the technical, but I think there are resistors involved. Not sure if they run optimal at a different voltage.
    GregM likes this.
  15. scozz
    Jul 20, 2008
    5,431
    12,670
  16. Jethro Rocker
    10,237
    15,708
    Pre amp 10. I turn it down for cleanish which is rare. I also have a Lynch Mod in V2 with level about 1 oclock. Old school and 80s metal. Goose the front with an OD as required as well if gain set lower.
    Yep cathode boas. Plug n play. They are also runjjng at a lower voltage so almost any octal tube goes. I have KT88s in mine.
    Mitchell Pearrow, LCW, markm and 4 others like this.
  17. junk notes
    Dec 10, 2018
    3,278
    3,909
  18. scozz
    Jul 20, 2008
    5,431
    12,670
    I’m all over the place with the preamp, anywhere from 4 to 8. If I’m running it on or around 4, the master would generally be around 7 or 8,… and if I’m running the preamp up around 8 the master is low around 4. That’s generally the way I run it :cool:
    There’s no rhyme or reason for these settings, there’s no core tone I’m after, I’ve never chased any particular tones. This amp has the tones I like up and down the dial! Add a Sd1 or a Tubescreamer and rock on! :agreed:
    Mitchell Pearrow, markm, LCW and 2 others like this.
  19. scozz
    Jul 20, 2008
    5,431
    12,670
    How do those kt88 perform compared to el34s Jethro, I’ve heard they have a bit more low end, are you seeing that?
    Mitchell Pearrow and LCW like this.
  20. Jethro Rocker
    10,237
    15,708
    Sort of. Not as drastic as I thought it might be. Beefy for sure.
