The Official Marshall Dsl40cr Information Thread
Discussion in 'Marshall Amps' started by Bownse, Feb 5, 2018.
  1. Tom Drouhard
    Tom Drouhard New Member
    May 22, 2021
    13
    16
    Do you run your dsl40cr with the Master volumes wide open? On mine, I found that is how I get clarity out of mine
    Matopotato and Mitchell Pearrow like this.
  2. Mitchell Pearrow
    15,017
    29,530
    Welcome to the forum
    They are killer amps, with quite a few tones in them..
    Cheers
    Tom Drouhard, scozz and Bownse like this.
  3. Matopotato
    Matopotato Member
    Mar 3, 2021
    45
    38
    Almost all at 12 o'clock. Sometimes Gain on Clean down to 9 o'clock. Will try this though.
  4. 5stringsdown
    5stringsdown Member
    Apr 10, 2020
    64
    100
    Wide open is definitely the best tone imho.
    Bownse and Mitchell Pearrow like this.
  5. mwaley
    mwaley New Member
    Jan 17, 2020
    12
    16
    So, I'm baffled here. Why do these great DSL40CR threads die on the vine like they do? 13 great pages then the last post was May 29, 2021.
    I just don't get it.
  6. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,606
    1,454
    Adelaide, South Australia
    I guess things get covered in other posts :shrug:
  7. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,361
    2,433
    People tend to post with problems. These are easy amps to get good sounds out of. People are happy.
  8. tincbtrar
    tincbtrar Active Member
    Feb 19, 2020
    68
    118
    When I had the DSL40CR it sounded better with the master at around 7, IIRC. That is when the power amp was engaged. Anything more than that just added noise - but the gain/volume/eq all worked better as a result. In theory I should have used an attenuator, I might have kept the amp.
    Even the stock speaker was pretty good (the V-Type). I think a Marshall vintage speaker (not the V30) would be a good match too. When I think of the DSL, I think of Jubilee/900 but with more scooped mids (I would keep those pretty high at all times, at least 7 instead of 5). Tube wise, anything low noise in v1,v2 was ideal with the chinese driver tubes in v3,v4. Really great amp, but I sold mine and the Origin at the height of gear madness and got quite a bit back.
    Mitchell Pearrow and SkyMonkey like this.
  9. Bownse
    Bownse Well-Known Member
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    A lot of the stuff in the C threat can apply and that may be where some start.
    Speakers, I found the OEM 70/80 to be shrill but when paired with a 75w Creamback into a paired de-headed unit, they are complimentary.
    https://fjr-tips.org/misc/amp/DSL40C_Mod/A_Project.html
  10. SkyMonkey
    3,609
    5,023
    Yours came with a V30?
    OEM for these amps is a V-Type (CR) or a Seventy/80 (C).
  11. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    dupe
    SkyMonkey likes this.
  12. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    You're right and I misspoke. The link details things accurately instead of depending on my CRS. I fixed the above.
  13. Matopotato
    Matopotato Member
    Mar 3, 2021
    45
    38
  14. Cooltouch
    Cooltouch Member
    Mar 3, 2014
    30
    9
    Houston, Texas
    Okay, here's a totally nontechnical post, and one that I think most everyone here can get into.
    I just bought a DSL40CR a couple weeks ago, and I haven't had a whole lot of time to spend with it. I've just done the obvious -- checked out the clean channel, and then overdrove the amp and tried it out that way. But what I'm after are more basic, sort of pure Marshall sounds. I think of a Les Paul through a Marshall and I can hear the guitar's wood. I think of a Strat through a Marshall and I hear Hendrix and that Super-Strat neck pickup sound.
    I'm part of the way there, especially with my Strat. I'm getting to where I can coax some nice sounds out of the amp, but I would like more. Far as my Paul is concerned, I'm not even close to getting the wood sound.
    So, assuming these settings are even possible with the DSL, are there any you'd care to share? TIA.
