The Official Marshall Dsl40cr Information Thread
Discussion in 'Marshall Amps' started by Bownse, Feb 5, 2018.
  1. J.LaGrassa
    J.LaGrassa Well-Known Member
    Jun 4, 2014
    607
    538
    Just as good
  2. Roag Jones
    Roag Jones Active Member
    Jul 31, 2019
    81
    103
    On my mg cab, I love that pos(added 2 vin30, 2 creamback75)
  3. Mitchell Pearrow
    13,468
    25,475
    Yea buddy I bet it sounds great.
    Cheers
    Mitch
  4. J.LaGrassa
    Jun 4, 2014
    607
    538
    Nice!! you using all 5 speakers?
  5. Mitchell Pearrow
    13,468
    25,475
    I do with mine[​IMG]
    Cheers
    Mitch
    Kochens, SkyMonkey, Bownse and 2 others like this.
  6. Roag Jones
    Jul 31, 2019
    81
    103
    Yes both cabs are 16 ohm
  7. J.LaGrassa
    Jun 4, 2014
    607
    538
    Got a new toy today, Epiphone 50s Les Paul Standard Gold Top. The Epiphone is surprisingly good with a nice chunky neck... it sounds great with the Marshall,
  8. J.LaGrassa
    Jun 4, 2014
    607
    538
    bought some new preamp tubes to try, got a couple of JJ ECC83MG to use in V1 and V2 and replaced the Chinese tubes in V3 & V4 with JJ ECC83S, kind of subtle but my initial responce was it sounds clearer and a touch more open. I'm pretty much using just OD1 with the gain between 10-12:00 thats plenty for me these days. But glad I got the ECC83MGs they sound sweet in the DSL40CR.
    SkyMonkey and Mitchell Pearrow like this.
  9. Bownse
    Bownse Well-Known Member
    Nov 16, 2014
    848
    590
    Ceti Alpha V
    Congrates. I had an Epi and you have to be picky when shopping Gibson replacements to get one better.
    J.LaGrassa and Mitchell Pearrow like this.
  10. J.LaGrassa
    Jun 4, 2014
    607
    538
    Thanks, really enjoying this guitar.
    Bownse and Mitchell Pearrow like this.
  11. J.LaGrassa
    Jun 4, 2014
    607
    538
    Not really an Issue but every once in a while I dont have Reverb, if I shut the amp off and turn it back on its back. Anyone else have this happen? I havent pulled the chassis yet Im thinking maybe a loose connector.
  12. Max Gahne
    Max Gahne Active Member
    Dec 1, 2020
    138
    164
    Just by chance, when this happens have you unplugged the guitar cable from the input jack when it was on? That's the only time I've had my reverb dissappear on my DSL1 - different amp but similar if not the same DFX unit. And turning it off and on brought the reverb back same as for you.
  13. J.LaGrassa
    Jun 4, 2014
    607
    538
    no the cable was in place, i did pull the chassis and checked all connections and they were all fine as well as the Digital board. I do use the 6 Button ft switch, it hasn't happened a lot but it does bother me a little.
  14. Max Gahne
    Dec 1, 2020
    138
    164
    I don't think there's anything wrong with my amp but rather a quirk in the design. I don't know but I suspect the DFX IC has the capability to turn the reverb on and off like the JVM's IC can, but that they didn't provide footswitch capability to use that function in the DSL. I think the DSL DFX IC can pick up a voltage ripple from somewhere, in my case from when the input jack ground switch closed when I removed the plug, and interpreted that as the signal to turn the reverb off. The default setting must be on which is why it came back on after turning it on and off. That's just my theory based on speculation. Mine hasn't dissappeared again since I've been careful not to unplug the input jack when it's on.
    J.LaGrassa likes this.
  15. J.LaGrassa
    Jun 4, 2014
    607
    538
    That sounds logical
  16. SkyMonkey
    3,262
    4,325
    Were both reverbs turned up?
    Another switching error could be switching reverb, but not channel, to a reverb that is turned down.
    Never heard of this but maybe a possibility.
    I never use the onboard 40CR verbs so wouldn't notice reverb errors.
  17. Bownse
    Nov 16, 2014
    848
    590
    Ceti Alpha V
    SkyMonkey likes this.
