The Official Marshall Dsl40cr Information Thread
Discussion in 'Marshall Amps' started by Bownse, Feb 5, 2018.
  1. SkyMonkey
    3,609
    5,023
    I think you may be being mislead about a 5-button footswitch.
    As far as I know the only features on the DSL40C that are 'foot-switchable' are the Classic to Ultra gain channels (i.e. whichever sub-channel is selected on the front panel), and the reverb ON/OFF.
    2 buttons is all that the DSL40C can use. :(
    From the manual:
    For the connection of the supplied 2 button footswitch (PEDL-00009). This allows you to switch between the Classic Gain and Ultra Gain channels (Note: The footswitch overrides the front panel Channel switch) and also switches the Reverb on/off.
    Bownse and Mitchell Pearrow like this.
  2. Bownse
    Bownse Well-Known Member
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    Understood. I have that one too. If the 5-switcher doesn't work that's on Sweetwater since I confirmed with them (C) before ordering.
    Mitchell Pearrow and SkyMonkey like this.
  3. J.LaGrassa
    J.LaGrassa Well-Known Member
    Jun 4, 2014
    607
    538
  4. GratefulDean
    GratefulDean New Member
    Jun 12, 2019
    8
  5. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    Nice. I may try that. Mine is at the bottom of the pedal board.
  6. Joseph Zaccaria
    Joseph Zaccaria New Member
    Jan 22, 2021
    4
    I just got a DSL40CL and you're right. It makes my tele sing. I had a Peavey Bandit 112 for 30 years and never liked the way the guitar sounded. Now have a whole new appreciation for it.
  7. J.LaGrassa
    Jun 4, 2014
    607
    538
    sweet, enjoy!!
  8. Mitchell Pearrow
    15,017
    29,530
    Welcome to the forum
    Enjoy your amp
    Cheers
    Mitch
  9. J.LaGrassa
    Jun 4, 2014
    607
    538
    Broke out the old Seismic Audio 1x12 extension cab just to try it out for a bit, haven't used it for a while but it will come in handy for those outdoor gigs! its a good fit for the DSL.
    matttornado, Bownse and SkyMonkey like this.
  10. mwaley
    mwaley New Member
    Jan 17, 2020
    12
    16
    J.LaGrassa,
    That's a perfect fit for the DSL40CR!. Looks like the Seismic 1x12 is an oversized cabinet, just like the DSL. Here's my DSL40CR atop my Marshall Clone 2x12 (Avatar Traditional 2x12). The DSL is almost as wide as the 2x12!!!! Untitled.jpg
  11. J.LaGrassa
    Jun 4, 2014
    607
    538
    So how are you guys utilizing the dual Master volumes? I was using it with one master Volume set as a solo boost but I'm thinking to use the Masters to balance between the clean/Crunch and OD!/OD2 and just stick a clean boost in the loop for leads.
  12. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    You were right. The 5-switcher didn't work. The C doesn't support the DIN connector that the pedal has. Sending it back.
  13. SkyMonkey
    3,609
    5,023
    What is the PEDL-xxxxx number on the 5-button?
  14. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    00021
    SkyMonkey likes this.
  15. SkyMonkey
    3,609
    5,023
    A PEDL-00021 is for the JCM2000 TSL-60/100. The Sweetwater guy must have had a brain fade!
  16. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    Refund on its way. Easy peezy.
  17. Randy Rhoads
    Randy Rhoads New Member
    Feb 25, 2020
    8
    7
    It may be just because I mostly just get to play at low volumes, but does anyone else find that the crunch channel's gain control does nothing after about 12 or 1 o clock?
  18. J.LaGrassa
    Jun 4, 2014
    607
    538
    might be subtle but i find it just gets a bit more saturated with increased low end, sounds fine to me at 12:00 with my Tele for some mild classic rock!
  19. Randy Rhoads
    Feb 25, 2020
    8
    7
    Okay, glad I'm not the only one :). How would you all describe the Crunch channel in relation to classic Marshall Amps?
  20. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    More affordable?
