The Official Marshall Dsl40cr Information Thread
Discussion in 'Marshall Amps' started by Bownse, Feb 5, 2018.
  1. Bownse
    Bownse Well-Known Member
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    Here's a branch of the original DSL40c thread. With the updated amp coming out and the original thread so long, it was wisely suggested that a new thread be started for the new amp and owners.
    Here ya go.
  2. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,776
    3,255
    Ft.WorthTX
    Love my new DSL40. Just retubed it with some old aperex pres and some Svetlana power tubes. Sounds awesome. Mine was factory biased around 34ma if any one is wondering. I set it to 32.
    ken361 likes this.
  3. MaskingApathy
    MaskingApathy Well-Known Member
    Jan 17, 2017
    311
    389
    Is 32 the recommended setting? Where do you all suggest biasing it?
  4. Bloodrock
    Aug 12, 2010
    2,776
    3,255
    Ft.WorthTX
    Usually anywhere in the low to mid 30’s is ok. Just depends on what sounds best to you. The older DSL’s had a bias spec in the 40’s, which was way too hot and caused a lot of poor sounding amps and shortened tube life. These new ones seem to come set to a much better range from the factory.
  5. MaskingApathy
    Jan 17, 2017
    311
    389
    What about the 100HR? Where would you set that? I've heard around 70 per side is a good place to start?
  6. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    4,275
    4,550
    detroit rock city
    mine is and my tech highly advises it, I tried other settings and settled on [email protected] 60% plate voltage 480
  7. Micky
    Apr 29, 2010
    21,153
    17,892
    Vermont
    It should be biased at less than 70%. It all depends on your B+ or plate voltage.
    MarshallDog and Bownse like this.
  8. wangchung
    wangchung Member
    Jan 10, 2014
    67
    34
    Hey Micky!
    I've been looking for channel bright cap I.D. on the new 40CR,
    and was wondering if you might have knowledge on this.
  9. Micky
    Apr 29, 2010
    21,153
    17,892
    Vermont
    Not yet.
    If someone sends me a schematic or better yet, a 40cr to reverse engineer, I will get right on it...
    Bownse likes this.
  10. wangchung
    wangchung Member
    Jan 10, 2014
    67
    34
    That would be most illuminating. I just got through rolling tubes and the final recipe with the Weber C123055 that I bought for the "other" 40C, is quite close to what I run in my 2kDSL50 head. The
    bright cap tweak would be the cherry. Y'all still have snow on the
    ground up there?
  11. Troy T. Blues
    Troy T. Blues Well-Known Member
    Dec 21, 2010
    443
    435
    Connecticut, USA
    Has anyone tried the loop via footswitch? I tried it last night with delay and there is a slight loss in volume. Is that due to the actual footswitch? I'll have to try and see if it does that or not without the footswitch.
  12. LCW
    LCW Well-Known Member
    Jan 18, 2017
    417
    670
    I found the opposite with a chorus. Was clearer and louder in the loop than in front. With footswitch plugged in.
  13. Troy T. Blues
    Dec 21, 2010
    443
    435
    Connecticut, USA
    :shrug:
  14. LCW
    Jan 18, 2017
    417
    670
    Maybe it depends on the effect...
    Bownse likes this.
  15. Bucky Berg
    Bucky Berg New Member
    Jun 12, 2018
    7
    8
    I got one from the Sweetwater blowout a little south of $400. Changed the speaker to Eminence CV-75 right away. Also put the same in an old Peavey Sheffield 1x12 and closed back. Could not be happier. I feel bad though for my Carvin V3M into an early 80s 1966A Marshall cab. It is sitting there collecting dust. And it is a killer rig.
    Micky likes this.
  16. Bownse
    Nov 16, 2014
    852
    596
    Ceti Alpha V
    You got a 40C or a 40CR?
    This is the CR thread. The C thread is about a bazillion pages long and chalked full of good info.
  17. keno beenz
    keno beenz New Member
    Jun 9, 2018
    5
    Just got my DSL40c and after putting Tung Sol 12AX7gold pin in V1 and a 50s RCA in the PI as well as JJs in 2 and 3 ,then switching toGroove Tube E34Ls power tubes and Bias at 44.8 (cause of the the power tubes ) and installed the Celestion 75watt cream back ..Im blown away .Id like to do some mods to get maybe cleaner tones in red channel, I dunno but im looking for suggestions ,thank you
  18. Bucky Berg
    Jun 12, 2018
    7
    8
    Sorry. Got the 40C
  19. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    1,523
    1,030
    I noticed the same thing with a boss dd3, ge7 or Joyo eq in the loop. when I simply put a jumper cable in the loop, I didn't notice the volume loss.
    Also, I notice that when the fx loop is turned on with one of the mentioned pedals, there seems to be a loss of preamp distortion.
  20. ken361
    Aug 30, 2009
    4,275
    4,550
    detroit rock city
