SV20C newbie questions
Discussion in 'Marshall Amps' started by Brogues, Jun 5, 2020.
  1. Brogues
    Brogues New Member
    Jun 5, 2020
    2
    2
    Recently picked up a SV20C but wondering (once my daughter is in bed) can I run the fx send through a Two Notes CAB M into headphones / DAW but leave the fx return with nothing plugged in? Does the amp still see the speaker load but effectively mute the speaker?
    Very nervous of destroying the amp within the first week of me buying it.
    Trident and Mitchell Pearrow like this.
  2. Mitchell Pearrow
    10,617
    18,070
    I have no experience with your amp brother.
    Welcome to the forum other more knowledgeable members here will be along to help you with your questions.
    Cheers
    Mitch
    MarshallDog and Trident like this.
  3. MarshallDog
    Nov 28, 2010
    14,087
    14,668
    Taintville
    Congrats on the new amp and welcome to the forum new MF'r!
  4. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,069
    1,651
    Las Vegas, NV
    Yes, the amp will still "see" the speaker, as long as the speaker is still plugged in. For that matter, I believe that on that particular model, the pre-amp & effects loop send will function even with the amp in STANDBY mode!
    Just Sayin'
    Gene
  5. Brogues
    Brogues New Member
    Jun 5, 2020
    2
    2
    firstly thank you all for the warm (tube-like) welcome!!
    gene - thank you for that, I will give it a go. I didn’t realise it might work that way.
    thinking on a bit further, I could take the fx send signal run it through the CAB M but with just the power amp emulation on (switch the cab emulation off) and then send to fx return. Then I could use the CAB m as a ‘volume pedal in the fx loop’ trick but also get emulated power amp which you wouldn’t get if you just use a volume pedal. In theory I’m thinking this would give pretty good tone through the speaker at low volumes? Has anyone have experience of this?
  6. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    3,827
    3,502
    detroit rock city
    I think the loops on the studio series kinda kill the tone some im leaving mine off
    tce63 likes this.
  7. Gene Ballzz
    Feb 19, 2013
    2,069
    1,651
    Las Vegas, NV
    While that may be the case, the other stuff that using a loop can bring to the party is worth the compromise for some folks!
    Just Sayin'
    Gene
    tce63 likes this.
  8. ken361
    Aug 30, 2009
    3,827
    3,502
    detroit rock city
    playing at bedroom levels the volume drop is pretty big with the master maxed its way less but there is some differance
