I have a 1959 mojotone kit that I recently built and I have been playing with some of the components and the way it’s set up. My favorite for hard rock/metal has been with the NFB resistor as 100k on the 4 ohm tap, 5k presence pot with a .68uf cap. It sounds great but the presence sweep does not honestly have much of an affect at all on the tone. The amp does have a lar/mar master volume. However this setting is a little too much for more mellow tones and found that the 8/16 ohm tap worked better in those situations. After reading about the variable NFB mod I decided to try it with replacing the 100k resistor for 27k and wired a 500k pot in series with it and moved the wire to the 16ohm tap. So the sweep on the NFB control does work and seems ok, however when I turn up the presence control it seems like it’s doing the almost same the same thing that the nfb control is doing and also makes the affect of the NFB control almost non-affective. Should it function like this? Also I am running the ppimv almost all the way open at this point into a fryette ps-100. Thanks
