Super Lead 1968 Shipping Soon...
Discussion in 'The Tone Zone' started by tremojem, Apr 27, 2016.
  1. tremojem
    tremojem Member
    Nov 15, 2011
    61
    16
    So my question is:
    In your opinion, which of these three would be better served as the clean boost in front of this Ceriatone amp?
    BB-AT Preamp
    AC Booster Comp
    RC Booster
    I certainly will try all with only volume maxed, zero on gain and eq neutral.
    Just wondering if you all had any experience with these pedals.
    I have all three and use them with my Tremoverbs, but I read somewhere that the BB preamp was likened to a Tube Screamer, but with some improvements.
    Thanks guys.
  2. thegaindeli
    thegaindeli Well-Known Member
    Oct 22, 2008
    1,881
    731
    USA
    Congrats! :)
    Those are all great pedals, but I implore you to purchase a Chase Tone Secret Preamp (EP3 preamp) pedal.
  3. jack daniels
    Aug 23, 2010
    6,697
    2,432
    OKC, OK
    Creation Audio Labs MK.4.23 - CLEAN BOOST PEDAL - PURE, TRANSPARENT, NOISELESS GAIN
    Factory Direct Price $ 149
    The most transparent clean boost pedal on the planet.
    Simply put, this is the cleanest, quietest and most sonically transparent boost pedal out there. You won't believe what you hear... and what you DON'T hear!
    • Clean Boost, unity to +24dB.
    • Pristine circuitry based on the Redeemer buffer.
    • Power stepped up for +28dB headroom to handle the hottest amp effect loops.
    • True bypass stock (buffer bypass optional).
    • Can be used as a DI to plug directly into the line input of any sound system.
    • Incredible 0.0005% THD+n.
    • Lower than -115dBu noise floor. Over 140dB signal to noise ratio possible!
    • Flat frequency and phase response from 20Hz to 20kHz.
    • Uses 9VDC 75mA standard center-negative 5.5 x 2.1mm barrel connector.
    • Small footprint 3.1" x 4.25".
    The sleek, chrome 16 gauge steel body will attract as much attention as your tone does. Use the MK.4.23 pedal as a straight forward clean boost for solo's, or push your tube amp into saturation for amazing overdrive. The MK.4.23 clean boost pedal has more than enough headroom to be used in the effects loop of any amplifier for stunning power amp boost!
    The MK.4.23 clean boost pedal can also be used as a DI to plug directly into the line input of any mixer or DAW interface with high fidelity results. Why use a standard DI which knocks your signal down to mic level, only to ride in the noise floor and be gained back up along with that noise by the mic pre? You can simply use the MK.4.23 pedal to boost your signal directly to line level and avoid all that noise. A great DI pedal for clean tracking in the studio and live as a bass or acoustic DI.
  4. dreyn77
    dreyn77 Well-Known Member
    Feb 18, 2012
    12,559
    2,857
    enjoy your non marshall amp! it really is Your product now.
