Studio JTM???? That would be awesome...
Discussion in 'Marshall Amps' started by Jakeboy, Jun 30, 2020.
  1. Jakeboy
    Jakeboy Well-Known Member
    Dec 15, 2010
    600
    379
    Missouri
    It would make sense for Marshall to issue a 15 or 20 watt JTM to complete the series.
    Has anyone heard any scuttlebutt or rumors of such a thing. I am almost ready to buy a SV20, but would likely hold out for a JTM type if they were to do so...maybe since the 45 is already only 30 watts they don’t see the need? A cranked JTM is still LOUD though. Just a thought on an amp I’d like to see Marshall sell.
    Maggot Brain and tce63 like this.
  2. Kinkless Tetrode
    Aug 17, 2017
    1,291
    1,702
    I not sure how they would engineer the power scaling with the tube rectifier? It might be the same or might be more involved.
    Other than the tube rectifier, the SV20 is probably close enough, because you can just plug in and play KT66s or 5881s. If you really wanted to get down to the details, converting V1 from a split cathode to shared cathode, and changing the slope resistor to 56k should not be too difficult.
  3. Jakeboy
    Dec 15, 2010
    600
    379
    Missouri
    I didn’t think the 6l6 types were compatible with an EL34 pin out?
  4. Matthews Guitars
    2,118
    2,894
    No? You'd better tell Mesa, then. Their simulclass amps have been able to swap between EL34s and 6L6s since the late 70s.
    Pin for pin an EL34 and a 6L6 share the same functions pin by pin. Some of the tube operating parameters are different but it's not difficult to configure an amp so that either will run. And let's not forget about all those Marshalls that just require a few basic component swaps and bias adjustments to be able to run EL34s, 6550s, or KT66s. (The KT66 is considered to be plug-and-play compatible with the 6L6.)
    You can't just unplug an EL34 from your Marshall, swap in a 6L6, and go. There's more to it than that. But rewiring the tube socket isn't necessary.
    Jethro Rocker, Jakeboy and tce63 like this.
  5. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    367
    692
    Az USA
    Edited due to me being a dumbazz.
    Carry on lol.
    Jakeboy likes this.
  6. Jakeboy
    Dec 15, 2010
    600
    379
    Missouri
    I didn’t know that ....I assumed some rewiring of the tube socket was indeed required on old Marshall’s and Fenders in order to move between 6l6 types and 34s. I learned something new today!
  7. Kinkless Tetrode
    Aug 17, 2017
    1,291
    1,702
    With the EL34 you need a jumper wire between pins 1 and 8 that isn't required for the 6L6 pin out. But the jumper wire doesn't matter to the 6L6 so if it's wired for EL34 it still works for 6L6.
    The studios are cathode biased, so you can just plug in and go with those.
    Jethro Rocker likes this.
  8. dro
    dro Well-Known Member
    Aug 1, 2015
    617
    1,029
    Blue Springs Mo
    would much rather have a JTM 20/5
    Maggot Brain and Jakeboy like this.
  9. Jakeboy
    Dec 15, 2010
    600
    379
    Missouri
    Me too...the JTM45 I owned was a completely different sounding amp then my JMP.
  10. Maggot Brain
    Dec 13, 2011
    617
    752
    Seattle, Washington
    I would be ALL over a JTM20/5watt.
    One of my favorite amps is 2 watts, so fun to crank it for the nasty good sounds but still be able to hear afterwords.
  11. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,081
    1,671
    Las Vegas, NV
    Anyone considering trying a 6550 in place of an EL34 should look closely at their power transformer specs, as the current draw for the heaters is higher for the 6550. Granted, it's not a lot more, but significant, especially if the amp uses four power tubes!
    With that said, any almost any octal with the same (6CA7) or lower (6V6, 6L6, KT66) heater current as an EL34, is totally plug & play in the all three of the Studio Series and even the DSL20, due to the cathode bias setup.
    Just My $.02,
    Gene
    lespaul339 likes this.
  12. dro
    Aug 1, 2015
    617
    1,029
    Blue Springs Mo
    Just wonder if the JTM would sport the GZ34. What makes the JTM what it is.
    steveb63 and jeffb like this.
  13. jeffb
    jeffb Well-Known Member
    Oct 11, 2011
    567
    918
    Does this mean I can run KT66 in my Origin 20???????????????????
  14. Johnny 99
    Johnny 99 New Member
    Apr 20, 2018
    2
    4
    According to Santiago, yes. I'm running 6l6s in mine right now.....
    jeffb likes this.
  15. jeffb
    Oct 11, 2011
    567
    918
    Thank you for the reply! I was wondering if I had killed this thread :)
  16. Travis398
    Travis398 Well-Known Member
    Dec 7, 2011
    572
    844
    USA
    I think you're the guy that started the rumor.
    Jakeboy likes this.
  17. Maggot Brain
    Dec 13, 2011
    617
    752
    Seattle, Washington
    Marshall spies, Give us a Studio JTM!
    I have dreamnt of owning the JTM1 to get some low volume cranked JTM sex BUT I just can't quite justify the recent prices for a 1 watt amp... Give us a low watt JTM please.
  18. Kim Lucky Day
    Kim Lucky Day Well-Known Member
    Aug 22, 2018
    240
    594
    I've certainly been on record for a smaller JTM to be added to the Studio Series lineup. The dollars would literally be jumping from my wallet to get one...
  19. marshalltsl
    marshalltsl Well-Known Member
    Apr 6, 2012
    610
    755
    Catalonia
    They did the JTM1 on 2012. I don't think they will do a studio JTM20.
  20. Jakeboy
    Dec 15, 2010
    600
    379
    Missouri
    Agree that any lower watt JTM would need the gz34 rec tube.
