stratburst
I've been going through my storage unit recently and discovered several amps I picked up years ago on a hoarding binge that I kind of, well forgot about. When I picked them up I intended to get them serviced but I didn't live near anyone that I trusted to go through them at the time, so they went into storage. Now that I'm in Nashville and have a tech nearby I can trust, I've been pulling them out one by one to go through them. Up for consideration today is a 1972 JMP50 lead with original OT and laydown PT. It's headed to my tech soon and I'm looking for input on what I should be asking for to restore it.
First up are the PI coupling caps, they have to go. Would this amp originally had the same Philips "chicklet" caps used elsewhere in the amp as bypass caps? I have not been able to source these caps anywhere but I do have some .022uF/400v mustard caps I could use if it makes a sonic difference.
I also note that one of the sockets have been replaced. Probably a little difficult to source a correct replacement. I can ignore that as it functionally is sound.
Although I use NOS tubes I do plan on adding some Welwyn screen resistors.
Any other changes stand out that I should address?
Cheers!
Cheers!
