Standby Switch Usage
Discussion in 'Other Amps' started by SLICKFASTER, Sep 26, 2020.
  1. SLICKFASTER
    SLICKFASTER Member
    Sep 12, 2020
    38
    62
    my amps standby rocker switch is not smooth and feels like it wants snap. Not wanting to break it...is it truly detrimental to an amp to not use the standby as a warm up stage and just keep standby switch on during initial start up??
    I know there are some amps without a Standby.
    Thanks
  2. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,608
    1,635
    house arrest
    Why not simply order the part. :) Why-dismiss-when-you-can-fix?
    edit: There is a recent thread on the Topic. It was concluded that for a Marshall this holds true and is supported in every Marshall tube amp manual. It it also correct that other amps do not use standby.
    IOSEPHVS likes this.
  3. SLICKFASTER
    SLICKFASTER Member
    Sep 12, 2020
    38
    62
    I’m looking on eBay n can’t find the switch.. the amp is a Red*Bear circa 98.. where Might one be found?
  4. junk notes
    Dec 10, 2018
    1,608
    1,635
    house arrest
    Try looking up "Red Lighted Rocker Switch". You will be able to verify the one you have.
    tce63 and SLICKFASTER like this.
  5. iwuk78
    iwuk78 Member
    Dec 11, 2015
    14
    25
    The standby switch on guitar tube amps is pretty pointless. It wont harm the amp to not use it.
    TXOldRedRocker, tce63 and SLICKFASTER like this.
  6. SLICKFASTER
    SLICKFASTER Member
    Sep 12, 2020
    38
    62
    I have now read all the concepts about the standby switch and it seems to be more of a mute switch than anything. I have always thought heating the tubes before full power up was the best way to go...now I’m not sure..
    Think I’ll pull switch check for any ID specks, measure and take some pics.. seems should be an easy swap....
  7. mickeydg5
    mickeydg5 Well-Known Member
    25,041
    12,015
    Use it, do not use it. Its a preference.
    Do not sweat it.
    I turn my amplifier power on then later hit the standby for use.
    When turning off I hit standby first then hit power switch afterwards.
    It is just because it has the options.
    When I walk away from an amplifier for a while and it is ON I hit the STANDBY to OFF to save energy.
    Honestly turning the entire amplifier OFF is best since it saves your filaments/heaters life if walking away for a long time.
    That is about it.
    SLICKFASTER likes this.
  8. mickeydg5
    25,041
    12,015
    Damn dude, how did you like my post so fast?
    Watching your thread, huh?
  9. SLICKFASTER
    SLICKFASTER Member
    Sep 12, 2020
    38
    62
    Late night...bored...
    Rolled out my half stacks n was disappointed about the old sticking switch... appreciate the support!!
  10. mickeydg5
    25,041
    12,015
    Man, do not worry about the switch and just play on.
