pdxfairview
- Joined
- Oct 18, 2021
- Messages
- 4
- Reaction score
- 4
Thank you everyone for all the suggestions!
Wiring: appears to be correct. The previous owner that swapped out the speakers also "upgraded" the wiring, which you'll see here in the photo. Per the wiring example, posted above, it appears to be correct.
Phase: I tried the battery test per above suggestion but I just couldn't see cone movement enough to say if they're moving in phase or not. If the wiring is indeed correct, is there still a chance of speakers being out of phase? And is there a different way to check phase? I do have a multi-meter somewhere around here.
Speakers: certainly possible they're not "broken in". They look basically brand-new to me.
Appreciate the suggestion to check out the G12-65 as an alternative to the G12T-75...I check that out!
