Spare tubes just in case?
Discussion in 'Marshall Amps' started by Chris Reed, Jun 14, 2020.
  1. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,665
    1,195
    UK
    I guess this is ideal - if you can manage to take 2 amps to every gig! I couldn't do that - I have a car packed to the rafters as it is!
    I take spare valves - but I agree - it would be a faff to try to change them mid set! I would try, though because a lot of my songs rely on the JVM flexibilty, and I use my rack effects....
    My absolute last resort is this:
    If it meant the difference between playing the gig and going home, I would use this ultra-cheapo Behringer thing.....I've only ever used it once - and that was though a totally clean Fender transistor amp at a charity gig! How did it sound? Surprisingly good, actually! I don't think the audience would have noticed that the sound wasn't coming from a Marshall!......
    Jethro Rocker likes this.
  2. scozz
    Jul 20, 2008
    4,392
    9,956
    Did you receive the new tubes yet Chris? I’m curious to hear how you like your new Dsl20cr.
  3. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    469
    549
    Yea what he said.....just as long as the spare power tubes aren't redplating when fired up.....if so the amp must be biased or you will damage the amp.
    spacerocker and Mitchell Pearrow like this.
  4. MemphisMarshallMan
    MemphisMarshallMan Active Member
    Nov 8, 2014
    256
    228
    I wouldn't have time between sets to swap out tubes at a gig. For emergencies I carry a cab simulater box that I can plug into like its an amp and that signal runs directly to the mixing board. It fits on my pedal board like an effect pedal, and I have the signal run back through the monitors so I can hear it.
    I doesnt sound as good as an actual amp but it does sound surprisingly good and will get me through the gig.
  5. Sg-ocaster
    Jun 1, 2020
    469
    549
    I've been stuck playing an od box into a di into the pa system be for.....
    Ugh.......that becomes a rough nite quick.....i usually keep a spare amp in the truck unless I'm doing a fill in gig.
  6. Jethro Rocker
    9,173
    12,429
    I mentioned the Taurus pedal amp earlier but I often take the little Peavey 6505 mini head. Small, 20 watts, 3 channel.
  7. Chris Reed
    Chris Reed New Member
    Jun 12, 2020
    10
    21
    Cheshire UK
    New valves in, the base holder springy things are very stiff and was worried about amount of pressure needed to insert new EL34s but eventually went in. Still working on finding the best tone for me and where to put the various pedals ie before pre-amp or in the FX loop. Volume on half power is LOUD not tries full yet. Clean channel has a lovely tone and dirty gives some nice crunch. Not convinced the reverb control makes much difference though. Time will tell but for now enjoying the sounds.
