Solder Flux Question....
Discussion in 'The Workbench' started by Gutch220, May 30, 2020.
  1. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    1,077
    884
    NJ
    So I've been using generic flux over the years without ever putting a lot of thought into the different kinds. I'd just buy whatever the local hardware store had.
    So I see that there's rosin flux, organic, inorganic, acid, in a jar, in a tube, activated, mildly activated, water-soluble, etc, etc.
    What's the best stuff/version to use on amps, guitar, effects, etc? (the stuff we talk about on this forum)
  2. Micky
    Apr 29, 2010
    20,907
    17,439
    Vermont
    Rosin flux is for electronics.
    Usually you can use rosin core solder.
    There is also liquid rosin solder you can use.
    Rosin paste flux is used for placing SMD stuff and soldering it.
    Never use acid flux on electronics. Never.
    SixStringr likes this.
  3. Gutch220
    Feb 19, 2018
    1,077
    884
    NJ
    what about activated versus mildly activated?
  4. Micky
    Apr 29, 2010
    20,907
    17,439
    Vermont
  5. Gutch220
    Feb 19, 2018
    1,077
    884
    NJ
    thanks. it sounds like I need either rosin flux paste or mildly-activated flux paste. which do you think is best to use/recommend? I'm leaning to regular rosin flux paste (not activated). I'm not sure how MUCH of a difference this will make though.
  6. ampmadscientist
    18,207
    12,283
    [​IMG] Alcohol based therefore clean with isopropyl 90% alcohol.
    thetragichero likes this.
  7. Micky
    Apr 29, 2010
    20,907
    17,439
    Vermont
    I use a liquid flux in a small plastic dispenser bottle.
    2 maybe 4 ounces, with a small needle dispenser.
    I've had it for years, I forget the brand name, probably Kester.
    I don't use it much because I use rosin core solder.
  8. Gutch220
    Feb 19, 2018
    1,077
    884
    NJ
    hmm?..... [​IMG]
  9. Micky
    Apr 29, 2010
    20,907
    17,439
    Vermont
    I don't have much use for paste flux.
    Only time I use paste is when I am soldering copper pipes.
    (yes, I do plumbing work too)
    Personally I think I you would be better off with a liquid flux.
    It is much easier to control how much you use.
    A little goes a long way...
    neikeel likes this.
  10. thetragichero
    Jun 6, 2010
    2,455
    618
    flo rida
    I've had a think of radio shack paste flux that size for about a decade and it's finally almost gone. I'll definitely look at liquid next because the paste isn't very fun to work with
  11. Nik Henville
    Jul 18, 2018
    1,635
    2,933
    A
    Flux
    Capacitor
    is in the wrong thread... damn.
    :hippie::pirate::uk:
    Seanxk likes this.
  12. ampmadscientist
    18,207
    12,283
    The flux is not for soldering.
    The solder already has flux in it.
    The flux is only for : DE-soldering.
    De soldering requires more flux and higher temperatures.
    And those who want to learn DE soldering, must learn to use the added flux.
  13. ampmadscientist
    18,207
    12,283
    No don't use paste.
    Use liquid rosin flux made specifically for electronix, non-corrosive.
  14. Ken Underwood
    Oct 16, 2013
    607
    1,449
    Annesley North Notts UK
    There is no need to use anything but multi core solder, why use flux when the solder already has it in it.
    You must always take off all the old solder first before you reapply the new.
    I think the problem here is that so many try to do there own, or others, repairs and read loads of links concerning soldering etc, most of which are from guys that do not even know the basics of electronic servicing and repair.
    So its a case of the blind leading the blind.
    I can assure you guys that multi core solder is the only thing you need to work on electronic kit.
  15. ampmadscientist
    18,207
    12,283
    The Flux Is for UN-soldering.------ Not soldering.
    The De-soldering Braid needs fresh flux to work properly. There is not enough fresh flux in the existing solder to make the braid work.
    Some fresh flux must be added, or the de-soldering braid doesn't work.
    2. The de-soldering braid must be clean shiny copper. If the copper is oxidized, the de-soldering won't work.
    3. It takes a higher temperature to DE-solder.
    Because the de-soldering braid copper is dissipating a lot of extra available heat.
    If there is not enough heat to compensate for the added copper braid heat dissipation, the de-soldering braid won't work.
    3 basic rules
    that make DE-soldering possible.
  16. Ken Underwood
    Oct 16, 2013
    607
    1,449
    Were have you been all you life, thats a load of tosh.
  17. Ken Underwood
    Oct 16, 2013
    607
    1,449
    This is all you need to know, read and learn......
    In soldering of metals, flux serves a threefold purpose: it removes any oxidized metal from the surfaces to be soldered, seals out air thus preventing further oxidation, and by facilitating amalgamation improves wetting characteristics of the liquid solder.
    Do
    you need to use flux when soldering? When soldering circuit boards, or other electrical / electronic devices, yes - you need to use flux. Fortunately, almost all solder for electronics use has an internal core of flux, so you usually don't need to add more
    FourT6and2 and Kutt like this.
  18. Ken Underwood
    Oct 16, 2013
    607
    1,449
    Simple explanation is that Flux is the glue in multi core solder that enables you to make a good clean electrical connection.
  19. ampmadscientist
    18,207
    12,283
    De-soldering:
    It doesn't work unless you add more fresh flux.
    This is why so many people cannot de-solder.
  20. Ken Underwood
    Oct 16, 2013
    607
    1,449
    Got nothing at all to do with de soldering, as long as you use a good clean iron, good quality braid, well impregnated, better still a good solder sucker, one attached to the end of you iron.
    Not unless i have been doing it all wrong for 57 years, the very first thing i was taught when i joined EMI at 16 was how to solder properly, that has been my bible throughout my whole working life in electronic repair.
    Frodebro and coolidge56 like this.
